Не открывается схема в 7.02
У меня Windows 11, загружено Kicad 7.02 и ночные Kicad 7.99. Схему разрабатывал в Kicad 7.02 и вдруг пишет “To open it you will need to upgrade Kicad to version dated 20230409 or later”. В Kicad 7.99 схема открывается, о там библиотеки другие… Как заставить его открываться на Kicad 7.02?
Translation:
I have Windows 11, downloaded Kicad 7.02 and nightly Kicad 7.99. I developed the scheme in Kicad 7.02 and suddenly writes “To open it you will need to upgrade Kicad to version dated 20230409 or later”. In Kicad 7.99, the scheme opens, but there are other libraries … How to make it open on Kicad 7.02?
Answer:
Most people cannot read Russian directly. Please use a translator if you post non-English questions.
Projects modified by nightly versions cannot be opened in earlier versions. Do not use nightly versions to do production work. If you have no wish to help find bugs at the cutting edge of development, do not use nightlies.
To add to @retiredfeline 's comments:
You developed a schema in 7.0.2, but you opened and saved that project in 7.99.
To fix your problem, you need to find a copy of your project that was saved in 7.0.2 and open that project in 7.0.2 and continue working in 7.0.2.
