leoheck
September 5, 2023, 8:50pm
1
This version is freezing every minute, I always have to kill it to continue, every minute. Anyone else with the same issue?
Not sure if it is related, but sometimes it shows this in the command line
✦4 ➜ kicad Base_Board_HW.kicad_pro
libva error: dlopen of /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so failed: /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so: undefined symbol: _ZN6GmmLib16GmmClientContext27CreateCustomResInfoObject_2EP33GMM_RESCREATE_CUSTOM_PARAMS_2_REC
libva error: /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so init failed
INFO: Created TensorFlow Lite XNNPACK delegate for CPU.
Opening in existing browser session.
^Z
[5] + 877780 suspended kicad Base_Board_HW.kicad_pro
Version: 7.0.7-7.0.7~ubuntu23.04.1, release build
wxWidgets 3.2.2
FreeType 2.12.1
HarfBuzz 6.0.0
FontConfig 2.14.1
libcurl/7.88.1 OpenSSL/3.0.8 zlib/1.2.13 brotli/1.0.9 zstd/1.5.4 libidn2/2.3.3 libpsl/0.21.2 (+libidn2/2.3.3) libssh/0.10.4/openssl/zlib nghttp2/1.52.0 librtmp/2.3
Platform: Ubuntu 23.04, 64 bit, Little endian, wxGTK, ubuntu, x11
Date: Aug 13 2023 23:14:43
wxWidgets: 3.2.2 (wchar_t,wx containers) GTK+ 3.24
Boost: 1.74.0
OCC: 7.6.3
Curl: 7.88.1
ngspice: 38
Compiler: GCC 12.3.0 with C++ ABI 1017
KICAD_SPICE=ON
eelik
September 5, 2023, 9:08pm
2
Do you have KiCad python plugins installed (and used)?
Did you just install updates for your system? Try restarting your system to see if the issue persists.
leoheck
September 5, 2023, 11:30pm
4
@eelik I have plugins. But I haven’t changed them since 7.0. And I was not using them now.
@craftyjon I keep my system updated every day, multiple times a day.
My uptime is 11h, I will try restarting…
Things I should consider…
The project is big and complex, but it was designed smoothly using versions from 7.0 to 7.0.6, so far. It is also done, I am just reworking a few small things post-fabrication.
I was editing footprints on another instance of the tool.
I noticed that Kicad was using all my 15 processors, and it consumed all the memory too (32GB)
leoheck
September 5, 2023, 11:36pm
5
Since it was frozen a lot I was killing it. I was also not removing the locks before starting a new instance of it.
These locks are here…
~Base_Board_HW.kicad_pcb.lck
~Base_Board_HW.kicad_sch.lck
I was just ignoring them.
leoheck
September 5, 2023, 11:38pm
6
Another important thing.
When it freezes the cursor changes to this plus sign with the carret (^).
leoheck
September 5, 2023, 11:39pm
7
I can’t close any window using the normal methods.
It happened again after rebooting.
leoheck
September 5, 2023, 11:49pm
8
Oh, it may be related to the save command. I use Ctrl+S a lot to save. Maybe every change. That happens every minute or less.
leoheck
September 5, 2023, 11:52pm
9
Now it is stuck, with the curson like this +^, the terminal does not show any bad thing (running with gdb). But the app is frozen, useless.
Kicad is using 100% of a cpu.
leoheck
September 5, 2023, 11:59pm
10
Maybe I found the issue.
I have a custom library and I put inside this library a symbolic link with its own name linking .
When I stopped gdb kicad, it told me this
Thread 1 "kicad" received signal SIGINT, Interrupt.
wxMBConvUTF8::FromWChar (srcLen=<optimized out>,
psz=0x55556fc21ab8 L"ib/My_Library/My_Library/My_Library/My_Library/My_Library/My_Library/My_Library/My_Library/My_Library/Precisio_HW_Libra"..., n=0, buf=<optimized out>, this=0x5555559bd3d0) at ./src/common/strconv.cpp:1378
Downloading source file /build/wxwidgets3.2-jjKGnf/wxwidgets3.2-3.2.2+dfsg/./src/common/strconv.cpp
This shows an endless recursion happening…
I would like to use my symbolic link.
Is this something that can be improved in Kicad’s code? @craftyjon
leoheck
September 6, 2023, 12:23am
11
Yeah, removing this symlink, fixed my issue.
With the symlink hidden (with the . in front of the filename), it does not work either.
Now, my question is why Kicad is trying to walk around my symlink? The
Kicad has a well-defined place where to look for symbols/parts. This place is defined here sym-lib-table and fp-lib-table.
And those files have a single and well defined path inside.
Base_Board_HW on post-fabrication-improvements [$!?] …
➜ cat fp-lib-table
│ File: fp-lib-table
1 │ (fp_lib_table
2 │ (lib (name MyLib)(type KiCad)(uri "${KIPRJMOD}/../My_Lib/My_Lib.pretty")(options "")(descr "My footprints"))
3 │ )
➜ cat sym-lib-table
│ File: sym-lib-table
1 │ (sym_lib_table
2 │ (lib (name "MyLib")(type "KiCad")(uri "${KIPRJMOD}/../My_Lib/My_Lib.kicad_sym")(options "")(descr "My symbols"))
3 │ )
system
Closed
December 5, 2023, 12:24am
12
