EDIT: The database connection problem was issue with .kicad_dbl file coming from the win system (my problem, see below). However, the crash issues still persist.
Kicad 7.0.3 just updated on my ubuntu-base pop-os and things are broken. I just got a board off to fab two days ago that was built with 7.0.2 (which was very solid). If I open that file on 7.0.3 and update pcb from schematic it crashes. If I run erc it crashes. If I try to add a schematic symbol it no longer sees my database. Anyone else seeing 7.0.3 oddities?
If I create a new project with 7.0.3 I can create a schematic but canât load from my database. However, I can activate the symbol lib directly and place parts. I can also run erc or update pcb from schematic and it does not crash like it did with my 7.0.2 project. This is what I see when I try to activate a database table:
Well 7.0.3 is unable to connect to a database for me, even if I create a blank schematic and try to place a symbol from a db into a black doc. If I activate my actual symbol lib I can place parts, so it is only a database thing.
I also get db error messages if the db is marked as active but not visible in manage-sym-libs.
The other problem I have is crashes when I use 7.0.3 to open a file created in 7.0.2 (I have same problem with two 7.0.2 files) and either update-pcb-from-schematic or run-erc.
However, if I open a file created in 7.0.1, I do not have the crashes. Also fine if I open a 6.0.something file. Very odd.
I moved the file I was editing in 7.0.3 on linux (that crashed when I went to update pcb) to a win system that has 7.0.2 and it opened fine with schematic edits intact, and can update pcb just fine â so 7.0.3 schematic changes did not bother 7.0.2.
I turned off wifi on this win machine so I donât get updated to 7.0.3 and will continue working on this isolated kicad laptop for now.
Which leads to a question: how to stop auto-update of kicad (both linux and win)? Then I can choose to update when I am not in the middle of a board design.
KiCad doesnât auto-update itself on either platform, but on linux your package manager will probably install updates âautomaticallyâ (when you tell it to update).
Windows: you have to install the updates yourself by downloading an installer from the kicad.org website, nothing automatically happens. You can turn your wifi back on if you want.
Linux: presumably you installed KiCad through your distributionâs package manager. I donât know how Pop OS works but on most linux distributions, your package manager will update your packages to the newest versions available whenever you tell it to run an update. The systems Iâm familiar with donât run this automatically - you run the update command and the package manager tells you what updates are available and you confirm. I would assume thatâs what Pop OS does too but like I said Iâm not familiar.
Thanks for the details @gkeeth. I need to look into the pop auto-update config. I will stay on the 7.0.2 win installation for now until I know if the crashes and database connection problems are related to 7.0.3 or perhaps specific to my installation.
I assume that you are running a flatpak install of KiCad (at least the build date in your version info matches the flathub stable build build time). In my local tests using this version, I can add symbols from a sqlite database library. Can you post the contents of the corresponding *.kicad_dbl file, esp. the contents of the "source" field?
If you go to the Pop OS software manager, can you check if the sqliteodbc Driver extension has been installed? This is required if you want to connect to an sqlite database using a flatpak install.
I canât tell how it should look for your distribution, but on Fedora (Silverblue) 38, in GNOME Software there is a section called âAdd-onsâ where you can install the corresponding ODBC drivers. Make sure that sqliteodb is installed:
Alternatively, you can run flatpak install org.kicad.KiCad.ODBCDriver.sqliteodbc from the command line to install the installation system-wide (use --user if you only want to install it for your user installation).
My kicad 7.0.3 linux system state is the same as yesterday â kicad cannot connect to the database. I can look at the db just fine with sqlitestudio or dbbrowser though. This database has been running properly on this system, and heavily used, for months now; the change that happened yesterday was the 7.0.3 update.
The pop-os package manager does not seem to have an add-ons or similar option to check. I tried the command line option and it says the driver is already installed:
gil@pop-os:~$ sudo flatpak install org.kicad.KiCad.ODBCDriver.sqliteodbc
[sudo] password for gil:
Looking for matchesâŚ
Skipping: org.kicad.KiCad.ODBCDriver.sqliteodbc/x86_64/stable is already installed
gil@pop-os:~$
Aaaaaaaaccchhhhh â my fault. I set kicad up on a win machine to figure out the database connection there, and I worked on that system for a few weeks to try it out (no dark mode, lots of icons look grayed out when they are not, but it worked well). I had made some db changes under win and brought those files back to the linux system â I forgot that the db connection was different between the systems.
Anyway, in the .kicad_dbl files under win, the connection looks like:
So that makes sense â I forgot all the hoops I jumped through getting the db running under windows and that the .kicad_dbl files had a different connection line.
Thanks for pushing me to look into the connection.
In general it boils down to installing the freedesktop SDK and KiCadâs debug extension:
flatpak install org.kicad.KiCad.Debug
Then Open a shell to the sandbox with flatpak run --devel --command=sh org.kicad.KiCad, run gdb /app/bin/eeschema, reproduce the crash and collect the backtrace via thread apply all backtrace.
Well this is wading into uncharted territory for me, but I tried the following:
gil@pop-os:~$ flatpak install org.kicad.KiCad.Debug
Remotes found with refs similar to âorg.kicad.KiCad.Debugâ:
1) âflathubâ (system)
2) âflathubâ (user)
Which do you want to use (0 to abort)? [0-2]: 1
ID Branch Op Remote Download
1. [â] org.kicad.KiCad.Debug stable i flathub 1.3 GB / 1.3 GB
Installation complete.
gil@pop-os:~$ flatpak run --devel --command=sh org.kicad.KiCad
[đŚ org.kicad.KiCad ~]$ gdb /app/bin/eeschema
GNU gdb (GDB) 12.1
Copyright (C) 2022 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-unknown-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<https://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from /app/bin/eeschema...
Reading symbols from /usr/lib/debug//app/bin/eeschema.debug...
(gdb) thread apply all backtrace
(gdb)
I am unclear if that was done correctly or not. I ran kicad and created an erc crash just before typing the âthread apply all backtraceâ part, but I really have no idea how gdb works, whether a dump was saved somewhere, or if I am doing this properly.
The best way is to open a confidential issue on GitLab and attach it there. If you cannot do that, you can also email it to me MOD EDIT: (PM me for email address because bots scrape web pages for them)
Forgot to add, after starting gdb, the first command is run, to actually start the program you want to debug. thread apply all bt you enter after the crash has happened.
The dump will then, by default, be written to the terminal.
