Good so far as I can tell (tested all features/tools that I use)… Thus, nothing to report on GitLab
NOTE: I don’t use .wrl for 3D so, I deleted all of the .wrl files and saved 1.3 Gig’s of file space.
Then, did Search&Replace (python code) to Bulk Change all of the Footprints in one-fell swoop (search for .wrl and replace with .STEP) over 13k lines were checked/changed(if needed) of them.
I wanted to test whether the default for PCB Editor / File / board Setup / Design Rules / Constraints / Copper to edge clearance had been changed from anything but 0 and following the instructions on KiCad’s website for Linux Mint (sudo add-apt-repository ppa:kicad/kicad-7.0-nightly) (+ update + upgrade) did not work. I’m still on V7.0.10.
After that I:
Renamed the config directory.
Verified this issue still exists in V7.0.10.
Started to create an issue / bug report for it.
Discovered an issue was already created on gitlab for this.
Added a comment to that issue (See below).
Edit: Deleted link to completely unrelated repository on gitlab. I just got lost on that one.
This issue was fixed already in the 8.0 release candidates but wasn’t pushed back to the 7.0 branch until today. It will be in 7.0.11 but is not in 7.0.10.
