[7.0.10] Color change to Locked items does not take. It remains the default magenta
As the title states. Tried 4 or 5 times. Clicked OK for the color picker and OK for the “Colors” flyout.
Also this keeps popping up when I go to PCB/Colors:
Version: 7.0.10, release build
wxWidgets 3.2.4
FreeType 2.12.1
HarfBuzz 8.2.1
FontConfig 2.14.2
libcurl/8.4.0-DEV Schannel zlib/1.3
Platform: Windows 11 (build 22621), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Dec 28 2023 21:18:15
Boost: 1.83.0
OCC: 7.7.1
Curl: 8.4.0-DEV
ngspice: 41
KICAD_SPICE=ON
Are you editing one of the default color schemes (read-only)? Or a new color scheme?
If you create a new scheme, it will start with the colors you have selected, so you can easily make a new scheme that’s the same as the default except with the lock color changed.
