This bug (?) is not a show-stopper, it’s only a bit baffling. In short, if the visibility of a property is unset in the property manager, and immediately after that a new item is selected on the board, the visibility of that property is not inserted into the property manager. One has to click twice on the item. Here are 5 screenshots that demonstrate the issue:
- H1 is highlighted, and the property manager shows that this label is visible.
- Then the visibility is unchecked, and the label becomes hidden.
- Next, H2 is selected with a single mouse click. This is reflected in the fact that the label is now highlighted. However, the visibility is still unchecked in the property manager.
- One has to click on H2 once more, at which point the visibility is checked.
- Now the visibility can be unset, so that H2 disappears.
Version: (7.0.0-rc1-253-g7844602210), release build
wxWidgets 3.2.1
FreeType 2.12.1
HarfBuzz 5.0.1
FontConfig 2.14.1
libcurl/7.86.0-DEV Schannel zlib/1.2.13
Platform: Windows 11 (build 22000), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Jan 18 2023 06:49:17
wxWidgets: 3.2.1 (wchar_t,wx containers)
Boost: 1.80.0
OCC: 7.6.2
Curl: 7.86.0-DEV
ngspice: 38
Compiler: Visual C++ 1934 without C++ ABI
KICAD_SPICE=ON
