jos
May 18, 2022, 9:23am
1
The git release number hash used to reflect accordingly within the version string.
Various gcc version compiles did not make a difference.
A fresh git clone did not make a difference either.
All that, distinctively AFTER an update/‘upgrade’ to 22.04
Any ideas from the devs or head scratching? Cheers
Application: KiCad
Version: 6.99.0-unknown , release build
wxWidgets 3.1.6
FreeType 2.11.1
HarfBuzz 2.7.4
FontConfig 2.13.1
libcurl/7.81.0 GnuTLS/3.7.3 zlib/1.2.11 brotli/1.0.9 zstd/1.4.8 libidn2/2.3.2 libpsl/0.21.0 (+libidn2/2.3.2) libssh/0.9.6/openssl/zlib nghttp2/1.43.0 librtmp/2.3 OpenLDAP/2.5.11
Platform: Linux 5.15.0-30-generic x86_64, 64 bit, Little endian, wxGTK, xubuntu, x11
Date: May 18 2022 21:05:30
wxWidgets: 3.1.6 (wchar_t,wx containers) GTK+ 3.24
Boost: 1.74.0
OCC: 7.5.2
Curl: 7.81.0
ngspice: 31
Compiler: GCC 11.2.0 with C++ ABI 1016
KICAD_USE_OCC=ON
KICAD_USE_EGL=ON
KICAD_SPICE=ON
Issue seems to be Linux only. Windows is ok.
unknown means that it was unable to use git describe in the source. You should see a line saying
Using Git to determine build version string.
in the CMake log for the build to show it tried to get the commit hash. If you don’t, then it means that CMake was unable to find the git executable. If you do see that, and if it still gives unknown, verify that the directory is still a valid git repository.
jos
May 18, 2022, 3:21pm
4
a command line git describe returns properly → 6.99.0-1918-g5edc03e85b
cmake is 3.22.1 with 22.04
seems to be a cmake version related process flow issue
in any case, cmake can’t find git at runtime
jos
July 18, 2022, 11:33pm
5
To whoever may find that curious,
by some KiCad developer team ‘magic’ the release hash suddenly showed up again.
Cheers
Application: KiCad
Version: (6.99.0-2526-ge8492f32ab), release build
wxWidgets 3.1.7
FreeType 2.11.1
HarfBuzz 2.7.4
FontConfig 2.13.1
libcurl/7.81.0 GnuTLS/3.7.3 zlib/1.2.11 brotli/1.0.9 zstd/1.4.8 libidn2/2.3.2 libpsl/0.21.0 (+libidn2/2.3.2) libssh/0.9.6/openssl/zlib nghttp2/1.43.0 librtmp/2.3 OpenLDAP/2.5.12
Platform: Linux 5.15.0-43-generic x86_64, 64 bit, Little endian, wxGTK, xubuntu, x11
Date: Jul 19 2022 10:23:46
wxWidgets: 3.1.7 (wchar_t,wx containers) GTK+ 3.24
Boost: 1.74.0
OCC: 7.5.2
Curl: 7.81.0
ngspice: 31
KICAD_USE_OCC=ON
KICAD_USE_EGL=ON
KICAD_SPICE=ON
system
Closed
October 16, 2022, 11:33pm
6
