Has someone tried the new cable size calculator tool that appeared in the development branch recently, like a week or two ago?
When I try to choose a cable size from the AWG table, or input a diameter or area in mm², nothing happens.
And there is no button to press to calculate, like in the Fusing Current calculator.
If I remember correctly, the very first nightly that contained the cable size calculator did calculate as soon as cable size was chosen or written in the input fields, but with any newer nightly I have tried, it doesn’t work.
I run fedora 35 and the nightly builds from copr, in case it would be build specific.
I could also add, that unless it has changed, it seemed on the first nightly I mentioned above, that did calculate some numbers, that the two last fields for voltage drop and dissipated power were calculated in Volts and Watts, despite the user interface stating mV and mW.
