in my design, I have some signals, which are connected to a hierarchical block. But then the ERC is not marking this signals, when they have no other connection in the design.
You can see, that signal ECU.EAL_SW_MON is only on one sheet (9) and nowhere else, but it isn’t marked (same issue with signals connected to a bus).
In the same design, on another place without the hierarchical sheet, the error is marked (couldn’t attach the image with the marker, because new user).
Is this intended?
Thanks in advance.
Application: KiCad-Schaltplan-Editor (64-bit)
Version: (6.0.0-rc1-20-gfe2844fb9c), release build
wxWidgets 3.1.5
libcurl/7.78.0-DEV Schannel zlib/1.2.11
Platform: Windows 10 (build 19042), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Nov 16 2021 12:01:06
wxWidgets: 3.1.5 (wchar_t,wx containers)
Boost: 1.76.0
OCC: 7.5.0
Curl: 7.78.0-DEV
ngspice: 35
Compiler: Visual C++ 1929 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
Good example-project. Now your intention is clear to see.
Regarding the opening question “is this intended, a bug or only a side-efefct of the current ERC-implementation”: sadly I can’t help.
A quick search on gitlab showed 2 open issues regarding ERC/label-tests, but both don’t focus on global labels. So I think it’s worth an issue at gitlab (kicad->help->report bug). The developers should know more about the internal ERC-behaviour.
