I’ve just made my 1st Multi part symbol (74HC125) so I’m just learning.
I’m not sure how the pin numbers are assigned to the parts of a multipart device.
This comment only refers to the table entry method:
Because I started using 1A, 2A, 3A, 4B, 5B etc the corresponding numbers we assigned to the correct part. However after completing the pin assignments I went back to remove the “A”, “B” … from the pin numbers in the table there is no column to identify which part the numbers are being assigned to.
Is it possible to add such a column?
After removing the remaining A, B, C from the pin numbers:
