In 5.99, I’m drawing a block diagram for a hierarchical design. The WIRE initially draws in Green, for a high power signal I’d like it to be Red and I’d like that to be in a single operation.
If I select a wire segment, then do “Highlight Net”, it appears to select the entire wire (it turns corners) as expected. ‘E’ pops up the Edit window where I can change line width and color. Entering OK applies the edit ONLY to the initially selected segment, rather than the entire net.
A block select is not an option as there are other wires within the block.
