5.99 crashing while using footprint editor
Crash occurred 3 times within an hour while moving and dragging (M & G keys) lines (f.court, f fab & f silk).
Anyone struck this problem or know of a reported fault before I try to work out exactly what is causing the problem?
Application: KiCad Footprint Editor
Version: 5.99.0-unknown-696619fdb6~142~ubuntu20.04.1, release build
wxWidgets 3.0.4
Platform: Linux 5.4.0-89-generic x86_64, 64 bit, Little endian, wxGTK, cinnamon, x11
Date: Oct 30 2021 22:22:12
Boost: 1.71.0
OCC: 7.5.2
Curl: 7.68.0
ngspice: 31
Compiler: GCC 9.3.0 with C++ ABI 1013
KICAD_USE_OCC=ON
KICAD_SPICE=ON
Several commits this week have been in the FP editor
There is a new version available now.
I’ll download that before I give the footprint editor a hammering again.
Thankyou @davidsrsb
Hmmm.
Problem is still there.
Will have to try to replicate fault.
Version: 5.99.0-unknown-153594b9ea~142~ubuntu20.04.1, release build
wxWidgets 3.0.4
Date: Oct 31 2021 22:22:53
Boost: 1.71.0
OCC: 7.5.2
Curl: 7.68.0
ngspice: 31
KICAD_USE_OCC=ON
KICAD_SPICE=ON
The problem persisted for two days. It was something to do with using the D, G & M keys while adjusting lines in the footprint editor, but I just couldn’t consistently replicate the problem; at least not to report a formal bug.
Now, and for the last two days, after repeated experiments, the problem has completely disappeared.
However:
Sometime, during the approximately ten crashes I had, I have lost all “layers” on my monitor except for Pads and their numbers when I open the footprint editor directly… no lines, arcs, texts, fills etc. in both my own libraries and Kicad libraries (f.silk, f.court & f.fab.)
I assumed I had just corrupted the programme with the crashes, so had waited for a new version of 5.99.
That version arrived today, dated the 4th Nov. but upon loading, didn’t fix my problem.
Any suggestions from anyone before I exterminate 5.99 and then reload it?
Also, what is the easiest way to completely and utterly remove 5.99 from Linux Mint?
It’s probably just preferences. Go to your preferences directory (it’s location will depend on platform but can be found by clicking the “Show Themes” button at the top right of one of the Colors pages in preferences).
Once you find the 5.99 directory, quit KiCad, delete everything in the directory, and then restart KiCad.
