Hi. I’ve been using KiCad for a while. I just upgraded to v5.1.8_1, on Windows, and am no longer able to open the Eeschema schematic editor. The other components work.
When I the schematic button from the main KiCad window, it opens a window with Project Rescue Helper at the top, two blank wide text fields, and below that, 2 images of a symbol. This window is frozen, shows a spinny wheel, and upon attempting to exit it KiCad crashes to desktop. Thoughts? Do I need to roll back to an old version? Thank you.
Check your Kicad preferences (Preferences > Configure paths, Manage symbol/footprint libraries).
Anyway issues like these should not cause kicad to crash.
Maybe you can upload the problematic project here?
I was able to fix it by installing 5.1.7, running Eeschema (At which point a similar window popped up, but didn’t freeze; It asked me to update my USB port symbol to a newer one), then installing 5.1.8.
I don’t know if this is in issue with that specific part (USB_C_Receptacle_USB2.0-Connector), or skipping a version when symbols are updated.
