When using the 3D Viewer, a Dimension (in White) shows up. Don’t know where it comes from.
A bit of problem solving shows erratic behavior BUT, it’s not one of my dimensions and it doesn’t disappear with hiding comments layer or deleting my dimensions.
If I deleted everything, it goes away. Piece-mealing the deletions shows that the last set of dim is somehow related…
Also, another question (rather than a new post): I’ve made several 3D models (using Freecad). All works well except that when loading/setting up the 3D links, I need to scale down my WRL files (from 1.0 to 0.4). There is no ability in FreeCad to change export wrl scale and I see nothing in Kicad to do this… ?
Use stepup to export 3d models as it scales the wrl model to the correct size
KiCad expects 1 wrl unit to be equal to some imperial size so you really need to scale be 1/(254*10^x) with x some number i no longer know off the top of my head
Thank you - not sure I’ll bother with Step-Up 0.4 works well enough (of course, with degrees in Eng & Math, determining ‘X’ is easy but would still need to enter on 0.4
The handy thing about Step Up is that it will take your input model, scale and rotate it to fit your footprint and export both a dimensionally accurate step model as well as a renderable vrml model. If you are using FreeCad anyway it seems counterintuitive to do the scaling in one application and any translation necessary to align the model in another application (KiCad). Step Up offers an awful lot more functionality too but the interface is easy to use.
The scaling factor is the reciprocal of 2.54 i.e 1/2.54 to convert from imperial to metric and is actually 0.3937 and not 0.4.
You can scale 3D models in KiCad while applying it on 3D viewer.
If you want change VRML file, you can edit with a text editor the file and apply a scale.
The VRML format is easier just by following some tutorials: http://rvirtual.free.fr/programmation/VRML/tuto_eng/tut2.html
