3d viewer: pcb is white, no tracks, no vias
Hi there,
I have a problem with the 3d Viewer.
It doesn’t show tracks, vias or the color of the pcb.
This is project related and works fine in other projects.
What could the problem be?
I’m using Kicad 5.02 and ubuntu 18.04.1
Any help is highly appreciated!
Kind wishes
AdrianBildschirmfoto%20vom%202019-03-27%2017-43-53
Do you have the entire board covered in silkscreen?
There is no KiCad V5.02.
If I look at the lower right corner of the PCB the white areas seem to extend yust beyond the edge of the PCB itself.
Maybe you drew something with a filled polygon instead of an outline on the PCB.
What happens if you look at another PCB?
There are some PCB’s in the Kicad-demos repository. Do they look OK?
You can twiddle with the settings of the 3D viewer.
3D viewer / Preferences / Display options:
You can also experiment with:
3D viewer / Preferences / Render Options.
YES!!!
How did that happen?
Great. Glad to see my guesses occasionally pan out.
:sunglasses:
