marera
March 26, 2023, 10:42am
1
Hi Folks,
with F.Cu layer switches invisible, the 3D viewer pos up (alt+3), but does not show the PCB.
Bug or feature?
Version: 7.0.1, release build
wxWidgets 3.2.2
FreeType 2.12.1
HarfBuzz 5.0.1
FontConfig 2.14.1
libcurl/7.83.1-DEV Schannel zlib/1.2.13
Date: Mar 11 2023 03:41:46
wxWidgets: 3.2.2 (wchar_t,wx containers)
Boost: 1.80.0
OCC: 7.6.2
Curl: 7.83.1-DEV
ngspice: 39
Compiler: Visual C++ 1934 without C++ ABI
KICAD_SPICE=ON
Piotr
March 26, 2023, 12:25pm
2
I have 7.0.1 at Windows 10 and even I switch F.Cu to be invisible 3D viewer shows my PCB.
marera
March 26, 2023, 5:01pm
3
I found out, that 3D is there, but paned far away.
Having F.Cu visible, the 3D PCB is centered from the beginning.
Strange, but nothing to put effort in, at least to me.
Maybe if others encounter the same, we should raise a flag.
m852
March 27, 2023, 5:25am
4
You can put a zero coordinate point anywhere on the board
marera
March 27, 2023, 7:18am
5
1: I’ve tried that, makes no difference
2: That does not explain why the behavior differs depending on wether F.Cu is visible or not.
system
Closed
June 25, 2023, 7:19am
6
