Hi
I have the defaults set on the 3D viewer but dosent look good at all, I have sat and played with board body colour and the two tone background but cant get a look I like is there a set of numbers people like ? can they be loaded in as a theme file or something or do you have to mess around I just cant get the stack up to look nice like a real PCB. Any thoughts peep’s ? I am using KICAD 6 and the latest release on a Windows 10 machine
Cheers
Andy
You may want to add version and os information. This could be something like a graphics driver, hardware, combo of, etc?
Thanks, I have added those details to my post.
Which operating system?
do you have realistic mode enabled in 3d viewer?
Thanks ! I have added windows 10, thats as much as I no about the PC
Don’t think so, I’ve never used that before version 6 and will check.
Hi @mousey
For future reference, to find the details other posters wanted:
Open Kicad, up the top click “Help”, then “About Kicad”.
In the top right hand corner is a button “copy version info”.
Left click that, then Copy into your post on this forum.
Thanks I can see how that would help and will do !
Is there any way of changing the colours? Can’t say they are bad but they look a bit washed out.
Application: KiCad (64-bit)
Version: (6.0.9), release build
wxWidgets 3.2.1
libcurl/7.83.1-DEV Schannel zlib/1.2.12
Platform: Windows 11 (build 22621), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Oct 29 2022 23:44:28
wxWidgets: 3.2.1 (wchar_t,wx containers)
Boost: 1.79.0
OCC: 7.6.0
Curl: 7.83.1-DEV
ngspice: 37
Compiler: Visual C++ 1929 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
The colours (as well as thickness and material) are set in the board stackup dialogue. “File” > “Board Setup…”
There is a separate dialogue for specialised finishes & edge connectors.
You can also choose the render the image using raytracing by clicking the highlighted button (much slower but much more detailed and accurate colour rendering.
Thanks. Do you know where the user-defined copper finish is set up?
Brilliant. I went into the Raytracing rendered and noticed the light all looked rather dark. When I reset them to the defaults it looks a bit different.
