Greetings,
I’m running the latest nightly in Linux Mint 18.2.
Everything seems to be running fine except for the 3D Viewer. When launching it, Kicad simply crashes.
Running from terminal shows some random code and then an “Aborted” message. The lines seem to be different each time. Some examples:
I’m having the same issue (3d viewer crashes and makes kicad stops working) but it happens with some projects. It was running ok, but stopped working after I tried to load a 3d model I made. I thought it could be some issue with openSCAD or freeCAD, so I created a new project and load only one component, then run 3d viewer and it went ok…
As you asked if the crash happenned with some specific project I thought you may know something about it and hopefully how to solve it.
You would be better off starting a new topic and giving your full Kicad information. Lots have changed in four years since this topic was last commented on.
You will find your full Kicad information in Help / About Kicad /. Top RH corner, just click “copy version info” then paste into your topic.
