3D viewer cannot be displayed
I installed KICAD 5.1.12 on WIN10 with BOOTCAMP on Macbook PRO, but it is not displayed in 3D viewer. However, it will be displayed if you set it to ray raytracing. I’m in trouble because I don’t understand the cause. Please give me advice.
*Raytracing ON >>3D View
*IF Raytracing OFF >> 3D not view
Check you have bootcamp setup correctly as the 3d viewer requires opengl2+ to operate and windows on a VM will default to software opengl1 unless you pass thru hardware. There’s a process to install bootcamp drivers that are supposed to enable it. You also need to manually install the video card drivers on top of that potentially.
You do know that KiCad will run natively on macOS, don’t you?
To.marekuru
thank you for the advice.
Currently, OpenCL V2.0 has the latest version of Radeon driver installed for Bootcamp. I also did a reinstall, but the results were the same.
Any good advice would be appreciated.
to.john_Pateman
Thanks for your comment .
I understand that it can be run on MacOS.
I was frightened by a warning that the software was not authenticated at the time of installation and stopped it once. I think that there is no problem from the information, so I will try it when it is absolutely useless on Windows.
・ ・ I’m trying with BOOTCAMP because I want to execute it on the Windows side due to circumstances.
