UPDATE: I realize there is a ton of info below, but I would appreciate if someone could just comment on the schematic at the end of this post. This would help me tremendously.
New to the group, but with all group members I hope to learn from you as well get some good info regarding a project I started over 10 months ago.
It all started with my 3D printer and a simple main board upgrade, but over the months it has escalated to much more. Primarily, a total rewire to include an external control box where all wires connect.
I have the beginnings of the control box (3D printed on another printer) completed, with the new upgraded main board installed.
Honesty Check⊠I am not an electrician, nor electrical engineer. But I am willing to learn if only someone would point me in the right direction. Most of what I have completed so far has been with the help of Google.com, and youtube.com
But I am now at the stage where even those donât help, I just donât have the background. This is where relying on the members of the group comes in.
Here is my next milestone, the creation of a schematic / auxiliary PCB and get power down to the main boards connection points. This is where power for all motors, sensors, fans etc, is drawn fdrom.
Here is where I am at on the first electronic milestone.
I have a power supply: Input 100v - 240v AC. Output 3 - 36v DC, 2amp using a DC plug
See Below for pics of specific parts
The DC Plug fits into the power jack, which is soldered onto the new printed circuit board (PCB). that I am attempting to create using KiCAD software for schematics and PCB creation.
Power is applied to the circuit board, it then flows through voltage regulator (24v max), through a push on / push off switch.
Power then flows through a resister/s or another voltage regulator (dropping voltage down to 3.5v DC), while a branch circuit will run to a 2 position terminal block, the wires then run down to the main board power terminal block.
As I mentioned before, I am way over my head, out of my comfort zone on this.
I would like to ask one favor though, and if you do respond to my need for assistance, please try not to use electrician terminology or language that will just confuse, and lead to numerous messages back and forth for clarity.
With that said⊠Here is my schematic thus far. Any suggestions welcomed. Also would like input on using capacitors before and after the voltage regulator, saw several references to this practice.
Was going to show the parts I was going to use, but new users only get one imbed object.
