I’m making custom footprints tuned to my project needs, but for *some* footprints the 3D models don’t show up in the 3D Viewer, however they do show up in the 3D Settings of the footprint.
At first I thought this was because I selected the step file for all my footprints, and that caused this issue without exception. However after selecting the wrl for all my footprints, there are still some left with this issue.
There is no difference between the 3D viewers in either the Footprint editor or the PCB editor. Both don’t show the model for these components.
I looked in the original and it uses the wrl. In fact, the 3D settings are now identical. Compare the original with my copy
Application: KiCad
Version: 5.1.5-52549c5~84~ubuntu18.04.1, release build
wxWidgets 3.0.4
libcurl/7.58.0 OpenSSL/1.1.1 zlib/1.2.11 libidn2/2.0.4 libpsl/0.19.1 (+libidn2/2.0.4) nghttp2/1.30.0 librtmp/2.3
Platform: Linux 5.3.0-40-generic x86_64, 64 bit, Little endian, wxGTK
wxWidgets: 3.0.4 (wchar_t,wx containers,compatible with 2.8) GTK+ 3.22
Boost: 1.65.1
Curl: 7.58.0
Compiler: GCC 7.4.0 with C++ ABI 1011Build settings:
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=ON
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=ON
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
nb. I couldn’t copy the version info at all from a fresh start of Kicad, and the “Copy to clipboard” button also didn’t work (copying from the text area in the main window worked). When I went and started Kicad from the terminal to look for any error messages, copy suddenly worked.
