hi,
I do not understand if I put a component of the kicad library in the schematic, then I associate a footprint, all well the 3d step is loaded automaticaly. If I add my components in the library schematic and pcb, all well , but the step file I have to go to manually associate … what am I wrong?
Nothing wrong. If you add your own components you have to manually associate step file as well, kicad will not magically guess which one it should be. In Kicad libraries that step is already done for you.
Maybe there is lost something in translation and I’m misunderstanding your question.
Ok.
Bat is possibile associate in my library the step file and save .
In this mode when in other projec use the same component thè step file is allready loaded.
