hi,
I have problem with 3D visualization, capacitor, inductor and resistor models are not found. I tried to install vers. 9 from shell and there is an error that does not complete the installation correctly.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://dl.google.com/linux/chrome/deb stable InRelease: The following signatures couldn’t be verified because the public key is not available: NO_PUBKEY 32EE5355A6BC6E42
Doesn’t look like this has anything to do with KiCad. It looks like the Chrome repository is giving problems. You could disable this Chrome repo, install KiCad, and solve your Chrome repo problem later.
I disabled the chrome repo, the error is gone, but there is more…
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
kicad : Depends: libgit2-28 (>= 0.28.1) but it is not going to be installed
Depends: libocct-data-exchange-7.6 (>= 1:7.6.3+dfsg1) but it is not going to be installed
Depends: libocct-ocaf-7.6 (>= 1:7.6.3+dfsg1) but it is not going to be installed
Recommends: kicad-doc-en but it is not installable
E: Unable to correct problems, you have held broken packages.
