I’ve search and searched and not come up with a solution.
I have some step files attached to footprints that correctly display on the kicad 3D viewer, there are no .wrl files in sight anywhere. Yet when I export the exporter says no model found and it is missing.
The main example is U19 which is the big SARA module
I’ve tried changing the filename from .STEP to .step with no change.
The paths include my 3Dmodels folder the kicad is using…
Kicad version :
Application: Pcbnew
Version: (5.1.10-1-10_14), release build
wxWidgets 3.0.4
libcurl/7.64.1 SecureTransport (LibreSSL/2.8.3) zlib/1.2.11 nghttp2/1.39.2
Platform: macOS Catalina Version 10.15.7 (Build 19H1011), 64 bit, Little endian, wxMac
wxWidgets: 3.0.4 (wchar_t,STL containers,compatible with 2.8)
Boost: 1.75.0
OpenCASCADE Technology: 7.5.1
Curl: 7.54.0
Compiler: Clang 10.0.1 with C++ ABI 1002
USE_WX_GRAPHICS_CONTEXT=ON
USE_WX_OVERLAY=ON
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=OFF
KICAD_USE_OCC=ON
KICAD_SPICE=ON
Any thoughts?
This does seem to occur for a large number of models i’ve manually assigned but not all.
