Several components are missing from the 3D file, for instance 0402 chips. How can I add them and if I add them, will it slow down creation and viewing of file.
This kind of error messages I get
Cannot add a VRML model to a STEP file.
Add component R31.
Add component R24.
Add component C33.
Add component U10.
Add component C32.
KiCad version and OS?
Of course, I forgot to add those.
Win10
Application: KiCad (64-bit)
Version: (6.0.0-rc1-220-ga224d8dd6c), release build
wxWidgets 3.1.5
libcurl/7.78.0-DEV Schannel zlib/1.2.11
Platform: Windows 10 (build 19042), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Nov 28 2021 12:00:02
wxWidgets: 3.1.5 (wchar_t,wx containers)
Boost: 1.76.0
OCC: 7.5.0
Curl: 7.78.0-DEV
ngspice: 35
Compiler: Visual C++ 1929 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
On my similar system the .wrl files are the default. I can manually change the footprint to use the also provided .step model
I see. Does it slow your machine if you put plenty of 3D parts in the PCB
Only 3D rendering, the KiCad pcb file embeds footprints, not the 3D model
