Hi, I am unable to find the schematic and footprint for the 5 pin 3.5mm TRS Female connector as shown in the figure. Please help.
P.S : Newbie to KiCad
Thanks in advance
Thanks in advance
While I recommend you give this a crack yourself - it is something you’ll need to do - that looks like the TRS socket that I’ve bought from Tayda in the past (To confirm, check this link to product page).
For my footprint: Tayda_3.5mm_stereo_TRS_jack_A-853.kicad_mod (2.2 KB)
And, here’s the definition of the schematic symbol (copy and paste into your own .lib file to use): JACK_TRS.lib (862 Bytes)
All standard caveats about getting what you’ve paid for etc etc apply…
Cheers, Geoff
Wow…Thank you, I will work on that!!
Thanks for the help. But could you please tell me about . dcm file?..Is there any way that I can generate one of those myself?
I didn’t realise that file existed. The format is very simple though. The entry for this part is:
$CMP JACK_TRS
D Stereo headphone jack
$ENDCMP
Entries are separated by a hash comment just like the .lib file.
Some of my parts have additional information such as a datasheet - they look like this:
$CMP ICL7660S
D ICL7660S
K Super Voltage Converter IC
F http://www.kcttek.com/uploads/soft/LP28056S-00.pdf
$ENDCMP
And the dialog where this happens in the GUI is this one in the symbol editor:
Well. I shall try it out…Thanks once again
Thank you!..I wil work on it:-)
Hi everyone, I’m new to the forum and kicad. I have the same problem as
Adityapanchangam, and I still haven’t solved it. I can’t download the library, can you resend the link?
From year 2016? Please at least open a new thread and give a fresh description of your needs. And I repeat what stryker already said back then… “I recommend you give this a crack yourself - it is something you’ll need to do”.
