Hello, reading the post about planes without net assignment but vias I remembered another question I have
When we wanted to seperate GND-Nets (GND, GNDA, VSS) we used 0R-dummy-resistors for the Schematic and connected the nets with copper, ignoring the DRC.
I think some programs have a special coupling-element to do this.
What is the correct way in KiCad to do this ?
just tested it. It does the job though I can not simply use a track. But I understand that there has to be an identifiable seperation Element for the SW. And I could define such SMD-Footprints according to my favorite track-width…
What do you mean by that? Did you want to use some copper element in the pcb side without a schematic symbol?
Yes, that’s how it’s done. Did you modify one of the existing KiCad net tie footprints? I have made one resembling a 0402 footprint with 0.16mm connecting copper strip. It can easily be cut with a knife if needed and even used as a resistor footprint. (GND nets may need thicker connection.)
