Can anybody please point out to me how to find 0.1" header library in KiCAD?
Similar to this http://electronics.stackexchange.com/questions/19182/where-is-the-eagle-component-library-for-0-1-breakaway-headers
In the new library system thereâs one called âSocket_Stripâ that has straight and right-angled footprints for that kind of header.
In the old system I think there were âHEADER_xxxâ type names in the pin_array module.
There is Pin_Headers.pretty library for straight and angled pin strips too (available in the new Kicad distribution)
And if you decide to make your own library, I recommend this method: https://www.youtube.com/watch?v=UB06W1EDyeU
I am using old system (seems the new system is not there for Windows). Canât find the âHEADER_xxxâ
I tried searching by keywords with âHEADERâ âHEADER_â but nothing comes
Chris,
I followed the link to make the footprint. I need 2x14 pin 0.1 inch header. So after making the footprint, I see below error in the pcbnew after reading the netlist
Module [U17]: Pad [~] not found
Module [U16]: Pad [~] not found
If you count, you will see it is complaining about 26 pins (not about 28 which is the total number). So it is recognizing only one pin per header (U16, 17 two different headers).
I think my schematic symbol library that I made doesnât match with the footprint through hole circular pad. Attached images. Please suggest.
nevermind, got it. Didnât assign pin number
Thatâs odd, I definitely have them in âconnect.modâ maybe I created them all.
I have mint connect.mod on my pc, and there is no header* modules there, however there are SIL1 to SIL28 modules which can be used for the same purpose.
Careful with the SIL* headers, They have a 0.8mm drill size which can be too small for the square pins on headers. Generally Iâd go with 1.0mm holes or whatever the manufacturer states in the datasheet.
thatâs good to know!
