Wrong symbols on PCB?
Maybe, possibly, probably. There are a whole lot of different XLR connector footprints for slightly different models and also for different brands. Connectors are by far the most troublesome footprint type because there are so many variations.
It’s not about track width but clearances, they are shown my the outline around pads . . .
0.2mm in Board constraints and Default Netclass
now 0.1mm in Board constraints and Default Netclass
0.25mm clearance means this device cannot be routed too as it has no clearance
which number should i change?
Btw. i can connect something to the preamp, just not to the xlr combo jack.
I guess that you don’t have a connecting Net then . . .
Im pretty sure its connected
grafik
The little squares and circles indicate open ends. ERC will also flag this. Have you run ERC?
Global labels for “inputs” and “outputs” have their attachment points on “opposite” sides. When in doubt, you can simply drag a label to the side. When there is a connection to the pin, then KiCad will draw the connecting wire in between.
