thanks @retiredfeline I also read in this thread that someone else just ignores these issues and submits and JLCPCB fixes it on their end? I wonder how reliable that is?
This is actually quite frustrating and surprising. The way I understand this is it is a lack of standards. KiCad uses one standard and JLCPCB uses another and there is no easy way to get from one to the other without installing more plugins or python scripts. In fact, there is a very nice plugin in the KiCad official library called Fabrication Toolkit for JLCPCB, does in fact produce all the correct files with proper headers for the position and bom file but, amazingly, when send over to JLCPCB, the orientation are all wrong on most components. Baffling.
Or too many standards. Manufacturers decide to do something different for their tape.
The plugin you mention is I believe by JLCPCB themselves. Perhaps you should ask them to incorporate orientation correction.
Itâs just one of those things in life.
Not sure itâs relevant, but I just submitted a board for fabrication by JLCPCB layed out using Eagle 7.7.0. After generating the Gerbers using the JLCPCB-supplied Eagle CAM job, I tried to view the board with KiCadâs Gerbview (7.0.7). The holes it displayed didnât line up with the pads, which concerned me. Checking JLCPCBâs support notes, I found that they generate drill files with 5 digits of precision, which causes trouble with many Gerber viewers. Gerbv showed the board properly.
Could this be related to the assembly problem described in this discussion?
I think yours is a different issue. People generally see rotation discrepancies of the part body.
With this plugin under KiCAD I solved my issues forever.
I dropped the âofficialâ plugin.
there is also a nice descriptive blog post
Yeah I know the process. Iâm using their facilities since a while.
But I want, in the preview, componentes set up correctly.
And this is what the not-official (but very effective and advanced) script does.
Just for everyone here. I did notice that JLCPCB updated their tool, so that by clicking each component, you can position it and rotate it at your wish
