Working with Solder Stencil openings
F.Paste and B.Paste. See What is the meaning of the layers in pcb_new and in the footprint editor? (KiCad 5 and earlier)
File->board settings (somewhere in there)
Make sure the center pad is made correctly (reduce paste coverage and paste areas split up. All footprints that ship with kicad have a reduction to 65% which is in the middle of the range i found suggested by manufacturers). Otherwise, you run into problems at the reflow stage (bad connections of outer pads as there is too much solder in the middle, problems with trapped gases, …).
