pointhi, You mentioned you want more Altium test files, complete with screenshots. how can I get those files into your hands?
just PM me in this forum
pointhi just PM me in this forum
Forgive me for my ignorance. Where’s the button for sending you a private message?
Click on a user’s avatar -> Message.
You need to be a basic user. New users do not have the option to send messages. Read a few posts or wait till an admin comes along to be promoted. See Understanding Discourse Trust Levels
Get to trust level 1 by…
- Entering at least 5 topics
- Reading at least 30 posts
- Spend a total of 10 minutes reading posts
(You are missing reading of one more topic)
ahh, that works but unfortunately an exception was raised - which from a debug point of view is good.
Now I can’t send this file
so is there any useful information that can be gleaned from this?
Check first on simpler files you may have, to verify your Altium version is broadly ok/compatible.
If you can spare the time, you could try delete of ‘likely suspects’ until the file does load.
Look at example here that have loaded, but complex shapes/pads might be a place to start.
you can just report the exception without the board. If its something like padstack != SIMPLE, thats actually a warning (which I implemented as assert in development, because it was so simple to integrate). Just click continue. The reason is that KiCad does not support complex padstacks yet.
I know, I need to improve warnings to look like in the eagle importer, where a list of possible issues appears at the end.
if it is any consolation, AtoK failed as well .
What Altium version do you use? Can you send me an empty boardfile?
The latest future roadmap
mentions initial spec by Orson for the padstack. Where to find this ?
Hi all,
I’ve just compiled a debug build of this branch of KiCAD. In case somebody also wants to do this, here are the commands I’ve issued after installing msys2 64 bit:
Cheers,
Cedric
pacman -Suy
pacman -Su
pacman -S base-devel \
git \
mingw-w64-x86_64-cmake \
mingw-w64-x86_64-doxygen \
mingw-w64-x86_64-gcc \
mingw-w64-x86_64-python2 \
mingw-w64-x86_64-pkg-config \
mingw-w64-x86_64-swig \
mingw-w64-x86_64-boost \
mingw-w64-x86_64-cairo \
mingw-w64-x86_64-glew \
mingw-w64-x86_64-curl \
mingw-w64-x86_64-wxPython \
mingw-w64-x86_64-wxWidgets \
mingw-w64-x86_64-toolchain \
mingw-w64-x86_64-glm \
mingw-w64-x86_64-oce \
mingw-w64-x86_64-ngspice
git clone https://gitlab.com/pointhi/kicad.git
cd kicad
git checkout altium_import
mkdir -p build/debug
cd build/debug
cmake -DCMAKE_BUILD_TYPE=Debug \
-G "MSYS Makefiles" \
-DCMAKE_PREFIX_PATH=/mingw64 \
-DCMAKE_INSTALL_PREFIX=/mingw64 \
-DDEFAULT_INSTALL_PATH=/mingw64 \
make -j 7 #adjust for your number of cores
make install
After that you can find start the executables from C:\msys64\mingw64\bin
After starting pcbnew.exe in stand alone mode, you can choose file → import non kicad board file, and point to your Altium file.
Issue the following commands to update KiCAD to the latest version:
cd ~/kicad
git pull
git log
cd build/debug/
make
make install
I’ve looked around in Kicad, the PCB editor and the schematic editor, but I could not find the “Import Altium project” button.
Did I look in the wrong place, or should I open Altium files in another way?
It was told above in the post #60: Work in progress: Native Altium Importer
Thanks, I’ve edited my post above (71) to reflect this
I have made an Altium schematic that failed to load in KiCAD. it generates the error “IO error: Unable to read file” Followed by the error “XML parsing error: ‘not well-formed (invalid token)’ at line 1”
I assume importing of schematic files is not implemented yet?
Steps I’ve taken:
- Open eeschema.exe by double click on it
- File-import non KiCAD schematic
- enter . into the file name
- double click Sheet1.Schdoc Now the error "Error loading schematic . IO error: Unable to read file " from sch_eagle_plugin.cpp:Load()line:397
- Click OK. now this error comes up: “XML parsing error: ‘not well-formed (invalid token)’ at line 1”
My versions:
Application: Eeschema
Version: (5.99.0-1010-gc165d4bde), debug build
wxWidgets 3.0.4
libcurl/7.68.0 OpenSSL/1.1.1d (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.3.0 libpsl/0.21.0 (+libidn2/2.3.0) libssh2/1.9.0 nghttp2/1.40.0
Build date: Feb 29 2020 20:26:55
Boost: 1.72.0
Curl: 7.68.0
Compiler: GCC 9.2.0 with C++ ABI 1013
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
KICAD_STDLIB_DEBUG=OFF
KICAD_STDLIB_LIGHT_DEBUG=OFF
KICAD_SANITIZE=OFF
Altium designer 20.0.13 build 296
Thomas’ importer currently only handles PCBs, not schematics. The “import non KiCad schematic” function only supports Eagle at the moment.
@nickoe
Are you making available nightly builds with this patch anywhere? The last link from you above seems to just have the 7-day-old build. If not, could you generate a new build and post the link here? Thank you!
It has been built a few days ago, just check the patched folder against the commit sha in pointhis branch to see how old it is.
I made an Altium file that crashes the importer. In altium 20, I’ve removed 2 tracks. Link to the file:
https://www.mediafire.com/file/kkdjos4gj1n3bmk/IceZUM_Core_HX1K.PcbDoc/file
Steps taken:
1 Run C:\msys64\mingw64\bin\pcbnew.exe
2 Choose File-import non-KiCAD board file
3 Navigate to the correct folder, set the filetype to *.pcbdoc and open IceZUM_Core_HX1K.PcbDoc
4 See the error “Unhandled exception class: St12out_of_range what: bitset::set:__position(which is 18446744073709551615) >= _Nb(which is 51)”
5 Press OK, and PcbNew closes.
My versions:
Application: Pcbnew
Version: (5.99.0-1012-g13f5d39e2), debug build
wxWidgets 3.0.4
Build date: Mar 3 2020 19:34:05
Boost: 1.72.0
Curl: 7.68.0
KICAD_SCRIPTING=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
KICAD_SANITIZE=OFF
Altium 20.0.1.3
