As I just found out: Apparently there is no DRC with such copper shape. Neither does the router honor them. I can happyly put a track of another net over it and nobody complains.
The footprint wizard is Stage 5: Awesome.
Here you go
Uses pads only, so should have no problem with pcbnew.
Also for square buttons :
Sure, that works just as well. Either way, you have no right to demand free cake without screws, nor does the free cake supplier have an obligation to provide you free cake without embedded screws.
I wasnât accusing you of that. I was accusing you of the âguilt tripâ thing people try to do with open software, where you suggest that if other people donât spend time helping you, then you will go off to find free cake somewhere else and somehow the developers should actually care about that.
Just about every free software has the following disclaimer :
THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES PROVIDE THE PROGRAM âAS ISâ WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK AS TO THE QUALITY AND PERFORMANCE OF THE PROGRAM IS WITH YOU. SHOULD THE PROGRAM PROVE DEFECTIVE, YOU ASSUME THE COST OF ALL NECESSARY SERVICING, REPAIR OR CORRECTION.
And KiCad is no exception. If you donât like, you are always free to walk away! You also have the freedom to help improve it, etc.
I am not demanding anything. I am just stating that this may be a major concern against what I think is the goal of the KiCAD team: To get people to use KiCAD (not only because it makes their work meaningful in the first place, but also because it means better library support from third parties and so on.)
As my current project is, IMHO, a pretty nice addition to the open source MySensors project and already on Github, I am also not letting myself being guilt tripped into âjust being thankful for everything and shut upâ.
But the fact that you are quoting a LEGAL LIABILITY disclaimer suggests that we are on very different pages anyway and for the sake of peace I am out of this discussion from here on.
Well no, it is very far from a major concern. I mean seriously, people are going to throw out KiCad because they canât do special pads very easily? Thatâs silly. Your requirement is one of hundreds of improvements to KiCad that people have suggested. KiCad can be used quite well in 99.9% of use cases as it is, filling in the remaining 0.1% is ongoing.
Thatâs a common misconception. In commercial operations, more users means more sales means keeping your job. For FOSS, none of that applies. It is sometimes said that FOSS developers are âscratching an itchâ, I think what motivates them is to create something that is technically good. The fact that others might find it useful is nice, but not a primary motivation. Certainly in all FOSS projects I have seen the developer discussion is always along the lines âwhat is the best technical solution?â, I have never seen any discussion along the lines âhow do we increase our user base?â.
That doesnât follow. You think contributing to a different FOSS project is somehow relevant here? Of course, you can complain as much as you like, but my point is that it is futile, and after a while just becomes annoying. Being thankful is nice, but the best way to help KiCad to do is find a way to make a positive contribution. Banging on about missing minor features that have been known about for years (and actually are being worked on), is just not helping.
Oh, I forgot to post the footprint wizard. To install it, it should be copied to (kicad)\share\kicad\scripting\plugins where (kicad) is the install location. Windows users may need to do that with Admin permission, start Windows Explorer with âRun as administratorâ.
contact_wizard.py (6.6 KB)
In my trials, I have found that transparent backgrounds produce nearly empty (headings, but no drawing data) .kicad_mod files.
Thanks, but we found that out already. It was indeed transparency.
On the contrary, you prefer to flog the dead horse! To be honest, you are the sort of user FOSS projects can do without. Despite getting all help possible, you still complain!
The feature you ask for is currently in development. What more can be done? They canât wave a magic wand and make the code appear. Someone has to put in the tough slog of writing the code, testing it, fixing bugs. Are you volunteering to do that? Are you helping write documentation? Are you helping users on the forum? Are you donating money to KiCad via CERN? Are you thanking people when they help you solve your problem?
To be clear, that is just my opinion, I donât represent KiCad project or developers in any way, I am just a user.
Really bad example, Nextcloud are a for-profit company. They make money from users.
Thanks, I appreciate that comment. I did not not want to imply that I got a FU from the KiCAD developers. It was a general interpretation of what it would be like if it would work as bobc descibes it.
I am actually really happy about all the help I got here, even from bobc. Right now, I got a working solution from that which will give me nice PCB, and if I look into the footprint wizard, it seems like I will even get a solution that will not potentially break my PCB at changes without warning (as right now, the copper polygons do not seem to be recognized by the DRC).
To recapitulate: At some point, the information was âyou can do it like this, but this will potentially break in upcoming versionâ (without being mentioned that at that point, a proper solution will be available). I stated that this was irritating and since then I seem to be discussing with bobc I I have the right to be irritated in such a situation or not. This hasnât been about KiCAD in special for quite a awhile.
I very much think I thanked for helpful comments. Also, the fact that this is in development was a pretty late information, I havenât complaint about the issue at all after that. The discussion has been mostly a discussion about the general legitimacy of critique on FOSS projects for a long time.
Isnât that Owncloud? Anyway, in that case is IS a good example, because I know that those particular people have other jobs.
Even if, is everyone using KiCAD at CERN a developer at same time?
If you reread this thread youâll see that @bobc alluded to the fact that this is expected to change in the near future in his very first post.
He then went on to help you draw the footprint you were trying to achieve.
You then complained some more about why it wasnât easier to do this in KiCad.
But then again in post 15 âŚ
And you continued to complain. Here we are on post 35 and youâre still complaining about one thing or another.
The question of arbitrary pad shapes comes up from time to time but it is not nearly the problem you seem to think it is. As far as I am aware everyone in the past has managed to work around KiCadâs limitations and create exactly the pad shapes they were after. Support for arbitrary pad shapes in currently in development. We canât tell you exactly when it will be available but hopefully in the next release.
Now, are you, or are you not, able to create the pad shape you need for your button? Is there anymore help you require?
I would really like to back out of this, but as long as I am accused of stuff that is simply not true, or asked stuff that I clearly stated before, that is really a bit hard.
He clearly did not. âhopefully in future versionâ does not indicate that at all. The whole situation arose from the fact that in post 6, bobc made clear that the only version I got at that point would be destroyed in future versions and NO other possibility was mentioned at that point.
In post 6, I asked why the possibility to do such things would be removed and if there was another intended way to achieve that (as it is usually the case when hacks get disabled). At this point âBecause an intended way is in developmentâ would have ended the discussion with an âOh great, thatâs awesomeâ.
Post 7: I get told that the reason the possibility for the hack is taken away was a lack of developers.
Post 8: I state that a lack of developers isnât really a good reason for programming a function that actively moves copper shapes into drawing layers. Further, I clearly and LITERALLY state, that I am NOT complaining about the fact that functions are not programmed by volunteers, but that I am irritated that active restrictions seem to programmed to limit the userâs possibilities.
Post 9-12: Perfectly civil and reasonable speculations why such decisions could have been made.
Post 13: First, IMHO totally uncalled for, implication that I am overly demanding, while on the contrary, I was asking for reasons why things were not left as they are.
Post 14: Again, me wondering about such a decision.
Post 15: Finally the actual answer that it was an upcoming feature. Unfortunately plus
- the statement that a remote control is an unimportant corner case and
- some lectures about software development âŚ
Post 16: Look at that. The promised âOh great, it is coming, KiCAD yeahâ post by me, plus - the statement why it is not an unimportant corner case in my opinion and
- a reminder that the only thing I was asking was how to properly do it. Again, at this point âSorry, for properly doing it you have to wait for the next releaseâ or âthere is a wizard that builts shapes from padsâ could have ended it with a âOk, awesome, then Iâll wait/try the wizardâ. Instead
Post 17: I get accused of demanding free stuff and saying that KiCAD sucks, and not being willing to put effort into the solution.
Post 18: Me politely explaining why I find this important again and why I feel that I may say that. Me clarifying that I am very much willing to put effort into the solution.
Post 19: Statement that had problems with the only solution so far.
Post 20: Offer for help, hint for a possibility to use my Inkscape drawing. Again, thanks for that.
Post 21: Second helping post, a few links. Again, thanks for that.
Post 22: Clarification that I independently found the issue, me sharing the footprint in case others need it, some answers to the help posts above
Post 23:Warning that the only so far suggested solutions puts copper on the PCB that is not controlled by the design rules. I felt that would be something some who was looking for the same solution should know. (Notice that lack of complaining about that.)
Post 24: Footprint wizard gets suggested. Sounds like the way to go for now.
After that, it seems to escalate and is not about KiCAD but the understanding of FOSS development in general. And I donât see my self at fault for that. In the whole process, I donât see me demanding anything, or âguilt trippingâ people into
anything.
Go ahead, show me a posting where I state any wish that this should be easier in KiCAD.
I was referring to the gist of your complaints, not necessarily any specific wording. Iâm not going to delve any further into who said what when.
What you need to understand is that KiCad restricts what can be placed on copper because the DRC is unable to check everything. For instance, as far as I am aware, the DRC is currently unable to check if an arc placed on a copper layer violates any clearance rules, or if it actually forms a connection, etc. But by manually editing the text files you can place an arc on a copper layer, circumventing the restrictions and rendering the DRC less reliable. In a future version, hopefully the next version, elements on copper layers that would normally be restricted from being placed on a copper layer will automatically be moved to a non-copper layer. Yes, this will break some arbitrary pads that people have created up to now but at the same time arbitrary footprints are also planned to be supported. As far as some RF features are concerned, hopefully the arbitrary footprints will support those as well, if not then that will need to be addressed separately once the needs have been determined.
Hopefully this helps explain why certain changes are being made to KiCad.
That has all been worked out in this thread. And I have repeatedly said that all of that is fine and I do not have any problem with that. The only moment where I stated concerns (NOT complained that it is too much work, NOT said KiCAD sucks and NOT âthreatenedâ to move to other software), was when only the bit on taking the functionality away was around, not the one on replacing it with a proper solution. as soon as that was added, I agreed that that was a sensible solution.
The only reason that we are at post 36 here is that certain people are not willing to understand that I did neither of the things in brackets and I am not willing to let contrary statements stand.
My previous post was simply an explanation, I made no such statements, accusations or implications. The post before that was fairly benign as well, so from this point on I will try to refrain from helping, explaining, or otherwise aggravating you any further.
