No, you don’t understand me correctly, when I try to copy a symbol and paste it, all the elements are the same. If I make a change now, all symbols will be changed. Only one element should be changed.
You’re in the wrong menu.
Go to the Symbol Editor and open your symbol. Then right-click outside the symbol in the white space and select “symbol properties”.
Then you’ll get the correct menu.
