jmk, My apology. I apparently missed your short answer, “mm”.
I was too focused in trying to find the screen you posted a photo of. I still haven’t found it. Perhaps there have been some revisions in the recent versions. I am presently using V 6.0.07. I need to download the later version, perhaps tonight.
I have apologized to jmk. I missed his short, but accurate answer in a longer post. If I offended anyone else, then I offer my apologies to them as well.
I am re-reading the thread and, so far, I do not see that answer anywhere else before your post which I have quoted. I will continue re-reading.
Comprehension of written instructions on specialist internet forums can be difficult.
Assumptions are made, pronouns can confuse, words missed or incorrectly interpreted, different levels of experience, English Second Language translations etc.etc. The list is almost endless.
Usually everyone finally makes it to the finish line.
The second number is the height? What does the height have to do with a footprint? Are the footprints actually 3D models?
I am sorry, but my mind tended to regard any reference to height as being bogus. Perhaps someone can explain that. And if so, can this be seen in the Footprint Editor?
Every footprint has a 3D-model assigned (or at least can have a footprint assigned - some 3D-models are not delivered in the standard lbraries). So if you want a correct 3D-representation from your board the height could be important.
in the footprint editor you have 2 options:
open the footprint → View → 3D-viewer (or hotkey “Alt+3”)
open the footprint → doubleclick empty space → get footprint-properties–>click pane “3D-model”.
With option 2) you have also the ability to assign an own 3D-model, or scale/move/rotate the 3D-model .
To be honest I also mostly ignore the height-value of footprints (and my personal ibraries don’T differentiate between different-height models), but I accept that it’s valuable for others.
Not all footprints are drawn with additional hand-solder-version. (for instance the polarized smd-caps are only delivered with one version).
In the standard-libraries the handsolder-version is placed in the same library as the normal version. Look into the already used Capacitor_SMD library: for simple 1206-ceramic caps you find:
The library is reflecting manufacturers Data Sheets. Height (length) and Diameter are always quoted in those data sheets. Here is just one of dozens of examples.
This thread is getting ridiculous. Learn to use the site and read the documentation and familiarize yourself with the program.
I think it is time to close it.
