Tutorials on python scripting in pcbnew
I have a new video and some new code. This time it’s about a way to record the actions of a pcbnew plugin. It generates a file listing all of the pcbnew calls made and sourcing that file should produce the same output.
There are two use cases I had in mind.
  1. creating regression tests. The kicad team doesn’t want your plugin code (I assume they don’t) but plugins are a great way to test whether something in pcbnew’s python has changed. So Instead of running the plugin, run a journal of a run.
  2. Learning how someone did something. Maybe I want to do something similar to someone else’s plugin. Maybe that plugin has some sections that I just don’t understand. Perhaps the math is not relevant to what I want, maybe I’m a new programmer, a zillion reasons. I just want to know how they got pcbnew to do a thing.
The code can be found here on github:
Here’s a video demonstrating the code and how it works.
I’m not 100% sure this post will be of interest to everyone, but…
I’ve been doing a fair bit with Boost’s c++ polygon and geometry libraries. These are libraries that enable one to manipulate polygons. merge, inflate, subtract. This can be useful for things like generating copper pours, design rule checking and more.
Since they’re c++ libraries (though the shapely is a wrapper around boost::geometry), they’re not directly python scripting. But since this thread is a clearing house of my writings, I’m adding it here.
I have other nerdly posting on my non-kicad blog: Using Boost polygon/geometry. Tutorial/tips/workarounds – Miles's Nerdy Thoughts
Here’s the video:
Hi @mmccoo, I’m getting an ‘internal server error’ when clicking on any of your links… Could you look into this? Thanks!!!
A post was split to a new topic: Manipulating Planes
iam creating a small plugin for pcbnew…i just want to get the path of the file currently opened in pcb new.since iam using os module of python to exectute some command, i need to change the directory to that particular path of file which is opened now in kicad.
@moderators
Usually old threads get closed quickly after they’ve been dragged up.
This one seems worthy to be moved into the FAQ section after some sanitation.
I don’t know much about Python, and have never used it in KiCad, so I have not read much of this thread and can not help here.
Take a look at the already published action plugins. Most of them are listed here.
This post actually predates the FAQ. It is a WIKI. I think @ mmccoo did this post as a request from me in another thread. So, yeah. :wink:
iam using kifield library to export and import the schematic data to and fro from excel sheet.Iam having a problem where export command when triggered from python program is working, but import doesn’t.when i run these commands from command prompt both commands are working fine as expected.Iam using os module of python to trigger the commands.Any help would be highly appreciated.
  1. use os.path.dirname() to determine directory of the file
  2. you need spaces after -i and before -w arguments
  3. use subprocess module to run
Thanks…That worked…but now iam creating one more plugin to add a data validation to the exported excel sheet. iam using pandas.The problem is when i import pandas in pcbnew console iam getting
ImportError: Missing required dependencies [‘numpy’, ‘pytz’, ‘dateutil’].
i downloaded a numpy zip and extracted to kicad/lib/python2.7/ sitepackages. then tried to import numpy.Iam getting this error message>
ImportError: Error importing numpy: you should not try to import numpy from
its source directory; please exit the numpy source tree, and relaunch
your python interpreter from there.
KiCad has moved on and is also using Python V3 now
Python V2 has finally been declared obsolete (that took 10 years too long).
To verify what Python version your KiCad uses, have a look at the version info, for example from Eeschema / Help / About KiCad / [ Show Version Info]. It should have a line like: “KICAD_SCRIPTING_PYTHON3=ON”
Installing Python libraries should not be done by downloading zip files.
Have you tried:
pip install numpy
There are still remnants of Python V2 lurking around. Sometimes you have to use “pip3” to install stuff for Python V3.x
If you are not on windows then use pip to install needed packages. If you are on windows and use nightly kicad then use pip from kicad’s install directory. If you are on windows and use 5.1 kicad then it’s more trouble than it’s worth to install anything depending on numpy because that build is using a msys2/mingw toolchain and requires numpy compiled on that toolchain. I advise to switch to nightly.
Ok…will try in that way. One more query here…Can we add a dropdown for value field in kicad eeschema symbol fields table. i can see a browse button in footprint library. similar to that on value field i need a dropdown of predefined values. how to acheive this?
Short of modifying and rebuilding kicad code, you can’t.
I need to read values from Comment fields in a script. Something like GetTitle() but for Comment. I don’t know how to do it. Will you help me? Thanks.
TITLE_BLOCK has GetComment(index) method
https://docs.kicad.org/doxygen-python-7.0/classpcbnew_1_1TITLE__BLOCK.html
Thank you very much for the advice, the command works. I just thought that in my case it would also load the content of the variable represented in the field. It just returns the name of the variable.
To expand text variables use
project = board.GetProject()
expandedvar = pcbnew.ExpandTextVars(var, project)
