I have a design that when generating Gerber plots, on a two layer PCB, I get a error D26 embedded in the Geber for the Top Solder Mask. I get no maks at all. The Bottom Cu mask is fine. What is wrong? Thanks.
KiCad version?
What is the exact text of the error message?
Where and when is the error message generated (gerber creation or viewer?)
Where do you Footprints come from? Are they KiCad’s, or from some 3rd party?
What happens if you delete the offending footprint? Is the rest handled normally?
The easiest way to duplicate / diagnose is if you upload the PCB file. (or even better, the whole zipped project). You can delete most of the schematic & PCB, as long as the offending parts are still present. This is even preferable, as smaller files make diagnosing easier.
Starters on this forum do not have the rights to upload files. You have to gain some “experience” and prove you’re human by browsing around a bit and reading posts for about half an hour or so. After that (or when a moderator grants you the rights earlier) you can upload files.
Already a basic user.
