I have problem with export to file STEP in Kicad 6.0. When I open step, a heve only pcb, without any 3dmodels. Is problem with generation of STEP in Kicad 6.0 ? This is also with sample projects. Problem STEP in Kicad 6 ?
log:
Read file: ‘C:\KiCad\share\kicad\demos\sonde xilinx\sonde xilinx.kicad_pcb’
Build STEP data
Add component R14.
Cannot add a VRML model to a STEP file.
Add component R9.
Add component R4.
Add component R13.
Add component J1.
Could not add 3D model to J2.
File not found: ${KICAD6_3DMODEL_DIR}/Connector_Dsub.3dshapes/DSUB-9_Male_EdgeMount_P2.77mm.wrl
Searched paths:
C:\KiCad\share\kicad\3dmodels\Connector_Dsub.3dshapes\DSUB-9_Male_EdgeMount_P2.77mm.wrl
Create PCB solid model
Build board outline (3 items).
Build board cutouts and holes (74 holes).
Generate board full shape.
Write STEP file
****** Statistics on Transfer (Write) ******
****** Transfer Mode = 0 I.E. As Is ******
****** Transferring Shape, ShapeType = 0 ******
** WorkSession : Sending all data
Step File Name : $tempfile$.step(7200 ents) Write Done
I don’t know about V6 (I’ll stick with 5.1.12). Nonetheless, I’ve done a handful of FEM Thermal Analyses in FreeCad where I needed the Pads and Traces.
I went through my usual process to figure it out and solved the problem. Knowing what to do gets it done about 90% of the time. Occasionally, it hiccups but, finessing the aspects of the solution fixes it.
So, what are steps to use? As follows:
You must have a Good PCB design, especially with respect to the Traces and Pads.
Then, the first thing to load in KSU (stepup) are the Traces (there’s an Icon for that).
Then, load the PCB/Parts.
You can write a FAQ article, you don’t have to be a moderator to do that. If your “trust level” isn’t enough to adding a post to the FAQ section or modifying the TOC, a moderator can move your post. I’ll promote you to “regular” level because you are a regular anyway.
