cannot confirm
Version: 7.0.0-da2b9df05c~163~ubuntu22.10.1, release build
wxWidgets 3.2.2
ubuntu Mate
cannot confirm
wxWidgets 3.2.2
ubuntu Mate
maybe try a re-install
I did it a bunch of times. I am going to try on a new system, maybe mine is broken somehow, then.
Everything is fine with your 22.10 system⦠This curve is an unfinished assembly with two shortcuts and no language packs
Iām not sure if I should start a new topic, but Iām having the same issue on Ubuntu 22.04 (Linux Mint):
22:07:42: Failed to load shared library ā/usr/lib/kicad/bin/_eeschema.kifaceā: /usr/lib/kicad/bin/_eeschema.kiface: undefined symbol: _ZNK13wxGLCanvasX1115IsShownOnScreenEv, version WXU_3.2
22:07:42: Error loading editor. Failed to load kiface library ā/usr/lib/kicad/bin/_eeschema.kifaceā.
Any ideas how to fix that?
I donāt run Ubuntu but from the message it looks like you donāt have the required version of wx something libraries.
Uninstall everything, remove the old 6.0 PPA if you still have it, add the 7.0 PPA, reinstall
Doesnāt change anything
Yes, it seems it has been linked to a another version of wxWidgets. But shouldnāt the builds in the Ubuntu PPA be build for exactly the specific version?
Do you have some custom version of wxWidgets installed from source or something like that?
I canāt help with Ubuntu, but for debugging you could find out what version of wx* itās looking for by:
ldd /usr/lib/kicad/bin/_eeschema.kiface | grep wx
Yes, thanks, that was the issue. At some point there was no wxWidgets 3.2 and had compiled it myself for some application. Since Ubuntu now has wxWidgets 3.2 that caused the problems. I deleted the the wxWidgets libraries from /usr/local/lib and now it works!
Thanks for the input..
ā ldd /usr/lib/kicad/bin/_eeschema.kiface | grep wx
libwx_gtk3u_gl-3.2.so.0 => /usr/local/lib/libwx_gtk3u_gl-3.2.so.0 (0x00007f7a0b51c000)
libwx_gtk3u_aui-3.2.so.0 => /usr/local/lib/libwx_gtk3u_aui-3.2.so.0 (0x00007f7a0b472000)
libwx_gtk3u_html-3.2.so.0 => /usr/local/lib/libwx_gtk3u_html-3.2.so.0 (0x00007f7a0b391000)
libwx_gtk3u_core-3.2.so.0 => /usr/local/lib/libwx_gtk3u_core-3.2.so.0 (0x00007f7a0aac7000)
libwx_baseu_net-3.2.so.0 => /usr/local/lib/libwx_baseu_net-3.2.so.0 (0x00007f7a0aa5f000)
libwx_baseu-3.2.so.0 => /usr/local/lib/libwx_baseu-3.2.so.0 (0x00007f7a0a79c000)
libwx_gtk3u_propgrid-3.2.so.0 => /usr/local/lib/libwx_gtk3u_propgrid-3.2.so.0 (0x00007f7a0a687000)
libwx_baseu_xml-3.2.so.0 => /usr/local/lib/libwx_baseu_xml-3.2.so.0 (0x00007f7a0a672000)
libwx_gtk3u_stc-3.2.so.0 => /usr/local/lib/libwx_gtk3u_stc-3.2.so.0 (0x00007f7a0a3ee000)
How do I interpret Kicad version? Focusing the wxWidgets it says that my system lib is wxWidgets 3.2 but Kicad was built with wxWidgets: 3.2.1. Is this correct? In this way, should I install 3.2.1 to make it work?
wxWidgets 3.2
Platform: Ubuntu 22.10, 64 bit, Little endian, wxGTK, ubuntu, x11
Date: Feb 14 2023 10:38:44
I dont think I have custom wxWdigets
This is all I have now, and both packaged are being installed with Kicad.
~ ā¦
ā sudo apt search "libwxgtk3*" | grep installed
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libwxgtk-gl3.2-1/kinetic,now 3.2.1+dfsg-4~bpo22.10+1 amd64 [installed,automatic]
libwxgtk3.2-1/kinetic,now 3.2.1+dfsg-4~bpo22.10+1 amd64 [installed,automatic]
Also, when I install Kicad
~ took 15.9s ā¦
ā sudo apt install kicad --reinstall
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
libwxgtk-gl3.2-1 libwxgtk3.2-1 python3-wxgtk4.0
Suggested packages:
wx3.0-doc
The following NEW packages will be installed:
kicad libwxgtk-gl3.2-1 libwxgtk3.2-1 python3-wxgtk4.0
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 48.2 MB of archives.
After this operation, 211 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
It suggests wx3.0-doc, and this is a bit wrong since there is this wx3.2-doc available.
It looks to me like you do, because system-installed wxWidgets is usually not in /usr/local/
Thanks, that indeed was the issue. I donāt recall having installed them because it was a long time ago. Those libs date from Jul 11, 2022. Doing what @Stefan-Olt did fix it for me. I removed manually all those outdated libs.
Here is the magic, if someone wants to copy and paste.
sudo rm -rf /usr/local/lib/libwx_*
Thanks @retiredfeline @craftyjon @Stefan-Olt
The next issue I am seeing is this one :
Did you also build wxPython from source?
probably. in the past I was testing some things with wxwidgets and I may have compiled it myself since the current version at that time was not working or it was missing.
I installed on a clean system 22.04 of ppa kicad 7 works but creates two shortcuts and there are no language packs on win 10 everything is fine
This file /usr/share/applications/kicad.desktop is a symlink. You can delete it, and one of the Kicad icons will disappear. This is a workaround while they donāt fix it.
sudo rm -rf /usr/share/applications/kicad.desktop
