I have a schematic that does not have any active circuitry.
For example, just a socket for an IC with pins going to test pins and some hardware holes for mounting the PCB onto standoffs.
I want to connect the mount points to GND. What symbols do you use in schematic for mount points? Will testpoint work or is there something better?
Also, when I connect 4 mount points to GND symbol, ERC complains GND is not driven. What’s the best way so that ERC doesn’t complain? Or is it OK because it’s an odd circuit that doesn’t have a proper schematic?
So you still have to use the PWR flag and the GND symbol, along with some symbol that will have a footprint, a footprint that will create a hole for M3 screw for example. OK, I haven’t been using the PWR flag.
