I updated to the nightlies this morning after having been away for a while and EEsched is crashing with a Segmentation fault whenever I select ‘Tools/Library Browser’.
That’s ok, it can happen with nightlies.
What puzzled me was the error message on the console:
Actually, EEsched failed to load any library, it seems, because it wiped all symbols from the schematic. Even resistors.
Sadly, I cannot produce a sensible stack dump for the bug report, because I am using binaries from a ppa that do not contain any names.
If I am the only one experiencing this, it might be that I have problems with my Gnome environment.
I will try to look into it a bit more tomorrow.
Still, you are right, a segfault should not occur…
First I checked an updated KiCAD installation on another computer. It had a couple of complaints, notably the sym-lib-table, but after that it did convert all the symbols in the schematic to the versions in the newer libraries. So at that point I knew the problem had to be on my machine.
Back at my own workplace, I reinstalled the kicad libs. That did not solve it. Then I reinstalled kicad. Did not solve it either. Then I removed $HOME/.config/kicad, forcing kicad to reinitiate.
After that it did complain about sym-lib-table and reinstalled the default. My poor schematic did not work yet, but at least kicad no longer segfaults.
So I removed my schematic and reinstalled that from backup. Now it behaves again. It did convert to the new libraries. Phew.
My troubles might have been caused by the fact that I have added some symbols to the libraries in the past, so I have changed the location of libraries to point to my local git repo to be able to test my own versions of some of the libs (with my added symbols).
