At the moment for the stable release the best way to do this is to use a simple SMD pad and use other software to generate the sequence of straight tracks to mimic your circular patch, then cut/paste into the kicad_pcb file. Alternatively, you can have a look at the custom shaped pads patch mentioned here:
