Questions managing libraries
Hi @SrSosio
I wrote this FAQ some time ago.
Reading it should answer most of your questions regarding creating and using personal libraries.
Please ask here if you have any questions regarding this FAQ.
To fix your problem:
After you have read the FAQ, create a new Global Symbol Library as the tutorial suggests and name that library “Switches”.
Move your created symbol to the new “Switches” library.
To do that:
  • Open your symbol editor and right click your created symbol in your old Library.
  • Select “Save as”
  • In the new window, modify the name if you wish.
  • Scroll through the underneath library list and left click select your new “Switches” library.
  • Save
You now have your switch symbol in your new Global Symbol library named “Switches”.
For your footprint, repeat the whole above process, with a newly created "Switches " Global Footprint Library using the footprint editor.
Next, replace your old symbol in the project you completed some days ago with the same symbol that is in your new “switches” symbol library and assign the footprint in your new “Switches” footprint library to that symbol.
If there is nothing else in your old personal library, that old library can be deleted.
Go to Preferences > Manage Symbol Libraries and delete your old library, then go to Manage Footprint libraries and delete the old library.
Finally, using your Operating System, find the old libraries in D:\Documentos\Kicad\ etc. and remove the old libraries from there.
This will all take a little time but when this is all completed, you will no longer have the error message and you will have your symbol and footprint in correctly made and named Global libraries in which more symbols and footprints can be placed in the future. :slightly_smiling_face:
Some final words on your library structure:
You used:
D:\Documentos\Kicad\7.0\projects\4wayswitch\PCF8575.kicad_sym
It would be better to use something like:
D:\Documentos\Kicad Personal Libraries\Symbols\Switches\4wayswitchPCF8575.kicad_sym
Reasons are:
  • Your personal libraries will still be used in some years time. Having \7.0\ will probably annoy you when you are up to Kicad 8 or 9 or 10.
  • Using \Documentos\Kicad Personal Libraries\ Symbols.… folders makes it convenient to use \Documentos\Kicad Personal Libraries\Footprints.… to keep the Symbol libraries folder in the same folder as the Footprint libraries folder.
  • \4wayswitchPCF8575. allows you to be able to name a 2 way switch \2wayswitchABC123 and place it in the same “Switches” Library.
These comments are only guides. It is worth spending a little time planning your personal library system now so it will serve you for years to come and you won’t, like me, and many others, regret their original setup then have to spend countless hours reorganizing them sometime in the future.
