Hello community!
I’m using pin header component and 3D models of pin headers are misplaced. I attached the image below. How could I fix this issue permanently?
Thanks in advanced!!
Hello community!
This typically happens if you mix version 4 footprint libs with version 5 3d model libs.
As you said, I did option 1 from:
and now is solved.
Thank you very much for your reply!
In Pcbnew click on the component press E for Footprint properties.
Under 3D Settings edit as needed.
