Ok, now it’s easier for me to give some opinions.
First, you said “tons of atomized configuration files”. I accept hyperbole, but there’s still only very limited amount of configuration files, and I think you already named those which belong to a project. So…
- Performance. Opening 100 files instead of 1 is much faster.
Do you really have benchmarking data which tells that on a modern hardware and modern OS there would be noticable difference between opening 100 instead of 1 configuration files, compared with the time spent on actually parsing those files? Let alone less than a dozen, which is more realistic for KiCad project configuration? I don’t think this argument stands.
- Disk space. Small files takes a disk space unit. Having tons of small file wastes disk space.
This argument is even weaker. We are talking about a few files, not thousands. And we are talking about systems with Gbytes of drive space, not about embedded systems. How many bytes the FS metadata takes? Any benchmarking?
- Maintainability of the code. Having tons of functions to deal with tons of files is much more complex than having just one.
Again, I’m not against rhetorical exaggeration, but we are talking about a few files and how many, two? file formats. What are those “tons of functions”? The amount of files has nothing to do with how many functions are needed to read them. The only drawback is that the files must be named in the code. But it’s far from “tons of” anything.
- I’m tired of explaining to new users at work which files must be included in a repo and which ones don’t. More files, more problem.
I would say this is more a problem in KiCad documentation, but also in your company’s workflow. For any reasonably good version control system you would have one centralized ignore file which can be copied or is used automatically. There shouldn’t be need to explain it again and again. And here’s a new idea: add ignore files to KiCad itself which can be automatically added (as an option) for a new project.
Here, again, the problem is something else than the amount of configuration files.
- Simplicity, the KISS principle.
“Make it as simple as necessary, but not more simple”. There are reasons for dividing the files. Complexion is added only if necessary. If there’s too much complexity because of, say, historical reason, it’s possible to reduce it. “The KISS principle” is easy to throw in but unfortunately reality is mostly more complex, and the principle is not an argument per se. You should argue why a certain implementation is too complex considering the needs and benefits.
- When you enter a directory and find tons of files you lose time.
That would be fixed by a better folder hierarchy, not by reducing configuration files. I would like to see subdirectories in a default new project, at least one for “configuration”.
