Well, it needs to be something that has a well-defined area. It might be possible to turn it on for pads. And there is a similar function for footprints: inCourtyard().
I kind of like padOf() though. But you might also want to know the parent of a zone or copper graphic item in a footprint. Maybe isChildOf()?
I think every basic graphic item has a well-defined area, namely inside the graphics. For example all straight lines – graphics and track segments – are oval or stadium shaped areas. Circles are rings (not filled circles). Footprints are not well-defined areas. Text aren’t either, or dimensions.
I have searched through a lot of posts and finally found this. I am trying to set rules using this system but I just cannot figure it out. It seems syntax has changed over time, it is really difficult to start testing this without a clear starting point. The whole selector is not even covered in the syntax help in 5.99.
My goal: set clearance between two net classes to a different value than clearance inside the net class. Currently I have the following:
However, this still sets a clearance of 3.0 mm between pads of components inside net class “HV”. I am really eager to use this but I am really missing a clear overview and explanation of the syntax.
Edit: this also does not work, here the 3.0mm is completely ignored:
To be complete: I need to set a clearance between all conducting parts (tracks, vias, pads) of all components in one net class and another. The clearance between parts of components in the same net class have to be much smaller. The application is isolation between high voltage referenced parts and low voltage side. This could also be achieved by adding a keepout zone with the correct width, but of course it would be much nicer to have this set in rules that DRC can use.
Yes, following this is increasingly more and more difficult. @JeffYoung, would this be a good moment to start a new thread with better introduction and continue with the newer expression syntax with some examples?
“selector” isn’t used anymore, you probably should be able to do it with costraints and conditions only. Selectors were replaced with expressions in the conditions.
I won’t speak for Jeff, but even though I know many people are excited about this feature, it might be best to hold off trying to use it for serious work until after feature freeze. The DRC system is still changing, and the rules system needs to keep up with it. Writing documentation, examples, etc. takes time that I think the dev team would rather spend on code before the feature freeze is in place.
I understand that, but I mean continuing this “guinea pig” testing, which would be easier if the current state would be better explained without need to browse through two gazillions of posts. Jumping on board now is difficult.
EDIT: most of the posts in this thread are now outdated in one way or another, pertaining to old syntax or already fixed bugs.
@eelik that sums up pretty well how I’m feeling as an outsider just coming across this, maybe just a fresh topic would already suffice to continue testing.
Is there any clue on which time scale feature freeze will happen and a release will be made? I know v6 has been in the works for a while and per the road map my guess still quite some time is needed for a stable release with its features.
This thread is for adventurous users who want to test a feature that is changing while they test it, and accept the pain and confusion that comes from doing so. I think it would be good to have another thread once we are at the point where the feature is stable enough that we want to do things like write more official samples, and avoid changing the syntax / doing other changes that confuse people. Before we are at that point, I’m not sure the value of a new thread.
Before feature freeze, I would like a feature that allows to specify another clearance if there is a slot inbetween. Sometimes we make another cutout and then a smaller clearance may be used.
Is it still true that edge cut clearance isn’t implemented?
Related to that, is there a reason why edge cuts should be handled as a special case? Could we define any layer with graphics as a condition for clearance rules?
