Need some guinea pigs for a rule-based DRC <<PROTOTYPE>>
Yes, this is on the roadmap (once we switch to expressions).
Thanks for working on this very welcome feature.
First thing I tried was to add “TrackToPad” 0.5mm rule that is greater than usual clearance 0.2mm rule:
(selector (match_type track) (match_type pad) (rule "TrackToPad"))
(rule "TrackToPad" (clearance 0.5))
It works! However it can’t be used as-is, because It needs not to work at the points where the track is connected to the pad.
I imagine the upcoming feature to have areas with relaxed rules would help.
I would then need to add areas around all the footprint pads in the design for this exception.
It is hard to put into words this requirement if I wanted this to be done automatically. The simplest thing I can think of in terms of possible rules is “do not apply this rule around the pads of the track’s net”.
@Nercury, see https://gitlab.com/kicad/code/kicad/-/issues/4279.
Thanks, I should have realized this must not be a new idea, since this is the first thing I tried and failed. Waiting for local area rules then!
Thanks for your proposals:
I tried the following:
(version 1)
(selector (match_layer GND2) (rule inner))
(selector (match_layer POWER3) (rule inner) (priority 1))
(selector (match_layer POWER3) (match_type board_edge) (rule innertwo) (priority 2))
(rule inner (clearance 0.3) (track_width 0.3) )
(rule innertwo (clearance 1.3) (track_width 0.3) )
does not work.
(I’m still using the same KiCad verison.)
I’m about to push an update that hopefully addresses some of the issues.
Main changes:
  1. Priority is gone. Selectors are evaluated in order; last one that matches wins.
  2. Distances need to be categorised as min, max or opt.
  3. Disallow constraints are now implemented. (They’re easiest to use with keepout zones, but they will work with any zone they match against.)
  4. Improved parse error reporting which puts your cursor at the error.
  5. Autocomplete for rule syntax.
  6. Syntax help.
    NB: the help is for the new syntax which will replace separate selector statements with condition statements within the rules. This is not yet implemented, so you still need to use selector statements for now.
Some examples:
(version 1)
(selector (match_netclass "Default") (rule "Big Gap"))
(selector (match_layer "In1.Cu") (rule "Big Edge"))
(selector (match_type track) (rule "Big Gap"))
(rule "Big Gap" (constraint clearance (min 0.5)))
(rule "Small Edge" (constraint clearance (min 2)))
(rule "Big Edge" (constraint clearance (min 3)))
(selector (match_netclass "Default") (rule "exclude"))
(rule "exclude" (disallow via))
I’ve played around with this a bit since I downloaded one of the earlier builds. I understand things have changed and they will continue to change.
Fair warnings:
  • I wrote Redirecting.
  • I’m an Allegro user with heavy Constraint Manager usage.
  • I do high-power designs including off-line AC-DC SMPS and that is an area where constraints add a lot of value to KiCad.
Here are some thoughts and observations:
  1. Rules don’t capture multiple layers
    If the clearance is different on different layers, which is almost surely will be, this requires multiple rules.
    And if those multiple rules together form one meta-rule, each of the rules needs to capture that commonality but yet have a difference.
    This results in rules something like “30V_internal” and “30V_external”.
    Would be better to allow one rule to capture many layers (and just a specific layer, too, of course) based on location and type:
  • All outer
  • All inner
  • All signal
  • All power plane
  • All mixed
  • All jumper
    Naturally, if this is handled with a GUI it’s not so painful to have to type out each rule but any UX would be better with a single rule name.
  1. Net class groups
    In offline power supply circuits with a primary and secondary domain, all nets in those domains must be kept apart.
    This currently requires a huge mess of constraints, encompassing every net class to be sure no nets are missed.
    If one of more net classes could be captured in a group then the groups could be constrainted with far fewer rules.
    Could have a single ‘primary’ net class group, single ‘secondary’ net class group, and one rule setting constraint between the groups.
    Another example would be grouping of nets on each side of a board-board connector or wires that need to be constrained the same.
  2. Pins and tracks/zones are distinct
    IPC-2221A has different columns for copper on internal layers, copper on external layers under mask, exposed leads, etc.
    Different clearance rules are needed for each of those three locations, and it’s messy to do right now.
    #1 above captures some part of it, but rather than having loads and loads of rules it would be easier to have a single smart rule.
    Could have a single rule named “30V” with different spacings for different elements: track-track, track-zone, pin-pin, etc.
  3. Clearance line around pads is generally wrong
    There is a clearance line around pads that indicates the clearance for the net.
    As there used to be a single value for the net this was a valid line.
    But it no longer applies across the entire board because the clearance between a pad and another other object can vary.
    The clearance line therefore is confusing, at best, and should be removed or somehow consider there can be many clearances to each pad.
@JeffYoung
If I should try a newer version, you’d like me to create an issue or issues on Gitlab for any of the above, or anything else, please let me know. And thank you!!
Application: KiCad
Version: (5.99.0-1730-g52ae0df7a), release build
wxWidgets 3.0.4
libcurl/7.66.0 OpenSSL/1.1.1d (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.2.0 libpsl/0.21.0 (+libidn2/2.1.1) nghttp2/1.39.2
Build date: May 20 2020 06:59:36
Boost: 1.71.0
Curl: 7.66.0
Compiler: GCC 9.2.0 with C++ ABI 1013
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
Thank you guys(@JeffYoung) for implementing my requests.
Some additonal feedback from my side:
  • Delete Key does not work
  • A comment function would be nice to quickly test rules
  • I find “A” and “B” not clear in the new syntax. I would propose to rename the variables to “self” and (“meet” or “contact”)
The following syntax does not work.
(version 1)
(rule HV
(constraint clearance (min 5mm))
(condition “A.netclass == 500V”))
Maybe a dev-version i got from nightly?
Application: Pcbnew
Version: 5.99.0-unknown-eae0c14~101~ubuntu20.04.1, release build
wxWidgets 3.0.4
Platform: Linux 5.4.0-31-generic x86_64, 64 bit, Little endian, wxGTK
Build date: Jun 1 2020 15:18:37
Boost: 1.71.0
OCE: 6.9.1
Curl: 7.68.0
Compiler: GCC 9.3.0 with C++ ABI 1013
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_PYTHON3=ON
KICAD_USE_OCE=ON
KICAD_SPICE=ON
The rules that involve two objects should be interchangeable (i.e. it should not matter which is “self” and which is “other”). So you could call them A and B, First and Second, etc.
@overthere, the new expression evaluator is not yet in the code. So no condition clauses will be read at present.
@Evan_Shultz, when we do have the expression evaluator, I think it will address many of your issues (or at least allow us to address them more easily).
You could imagine, for instance:
(condition "A.layer.name == In*.Cu && A.netclass == 30V")
(condition "A.layer.type == 'power plane' && A.netclass == 30V")
The clearance lines are definitely an issue, but they can be useful for simpler systems, and those using the rules can turn them off.
@JeffYoung
Yes. That would address #1 for sure. Thank you. If an element (‘A’, ‘B’, etc.) can be a track or pad or whatever, then yes, #3 should be addressed too.
I don’t see how expression help #2, but perhaps I’m not grasping it.
Yes, A and B are the two elements in question. They can be pretty much any item, although at present we only run the rules on copper items and edge cuts items.
They would help 2 by allowing A.netclass.group == blah, although such a construct would also need us to have netclass groups defined somewhere.
@craftyjon Yeah, I agree, that they should be interchangeable.
@JeffYoung please update us, when we may experiment with the condition clauses.
please can you help me with rule for checking F.Silks texts near to F.Mask pads.
Thanks.
Hi Jara,
In the current system it would look something like:
(selector (match_layer "F.Silks") (match_type text)
          (match_layer "F.Mask") (match_type pad)
          (rule "silk-to-mask-clearance"))
… but it won’t work in the prototype because we haven’t expanded the DRC engine to work on non-copper layers.
@JeffYoung: Just downloaded the current nightly version. I have trouble with the filling (key b) option. Tried this without success
(version 1)
(selector (match_layer “GND2”) (rule “Big Edge”))
(rule “Big Edge” (constraint clearance (min 3.0mm)))
version
Application: Pcbnew
Version: (5.99.0-1929-g4a3743e7d), release build
wxWidgets 3.0.4
Build date: Jun 8 2020 22:35:22
Boost: 1.71.0
OCE: 6.9.1
Curl: 7.66.0
KICAD_SCRIPTING=ON
KICAD_USE_OCE=ON
KICAD_SPICE=ON
Try it without the “mm”. I don’t think we’re currently parsing units (it’s based on our board format, which is always in mm).
@JeffYoung: It does not help for the copper pour. I think the problem in my version is, when clicking “OK” in the DRC, it does not evaluate. If i enter a wrong syntax, it does not raise any error messages. May it be, that the okay button is not working?
Doing a copper pour will not re-read the DRC rules. Running a DRC from the dialog (the “Run DRC” button) will. There shouldn’t be an “OK” button in the DRC dialog; are you talking about the Rules panel in the Board Setup Dialog? (That doesn’t re-parse either – although it probably should. Only Run DRC does.)
The next nightly will contain rule parsing on OK’ing the Board Setup Dialog.
