Moving footprints in PCBnew
I am fairly new to KiCAD and I am working on my first project. When I first started my layout, I was able to move a footprint by simply highlighting it and pressing m. However, that is not the case anymore. When I box a component to highlight it, it instead surrounds the component with a yellow box and then a pop up appears that says “Block Operation”. I attached an image of this below. I can still move the component doing this but it is more clunky and inefficient than the other way. Also, I used to be able to place a track fairly easy by just connecting two points. Now the track is translucent and requires me to right click and press end track to make the connection. Did I accidentally change a setting without realizing? How can I revert this? Thank you.
You might have switched to the legacy toolset. To get back to the modern one use F11
That fixed it. Thank you so much!
You need not to highlight element. Just press ‘m’ when your cursor is on the element.
