More via on a pad
Hey Guys,
Is there any sollution to put more than one via on a pad. I created exposed pad under the chip but I cant add more than one via, which is fairly poor sollution.
Thanks for help.
it is better if you make your footprint with pads as thermal vias…
The atch footprint may be similar to what you’re trying to do. Check out “Pad 21”. Take the footprint apart; modify it; study it; use as-is; or ignore it as you wish.
LTC4011_SSOP20_Pitch0_65mm_ThermalPad_Handsolder.kicad_mod (4.7 KB)
Dale
@maui means plated through holes when referring to ‘pads’
