ajay@ajay-Lenovo-G500:~$ sudo apt-get install python3-pip
[sudo] password for ajay:
Reading package lists... Done
Building dependency tree
Reading state information... Done
python3-pip is already the newest version (9.0.1-2.3~ubuntu1).
0 to upgrade, 0 to newly install, 0 to remove and 2 not to upgrade.
ajay@ajay-Lenovo-G500:~$ sudo -H pip3 install -U pip
Requirement already up-to-date: pip in /usr/local/lib/python3.6/dist-packages (18.0)
ajay@ajay-Lenovo-G500:~$ sudo -H pip3 install -U -f https://extras.wxpython.org/wxPython4/extras/linux/gtk3/ubuntu-18.04 wxPython
Looking in links: https://extras.wxpython.org/wxPython4/extras/linux/gtk3/ubuntu-18.04
Requirement already up-to-date: wxPython in /usr/local/lib/python3.6/dist-packages (4.0.3)
Requirement already satisfied, skipping upgrade: PyPubSub in /usr/local/lib/python3.6/dist-packages (from wxPython) (4.0.0)
Requirement already satisfied, skipping upgrade: six in /usr/lib/python3/dist-packages (from wxPython) (1.11.0)
ajay@ajay-Lenovo-G500:~$ kicost
You don't have the wxPython dependence to run the GUI interface. Run once of the follow commands in terminal to install them:
pip3 install -U wxPython # For Windows & macOS
pip install -U -f https://extras.wxpython.org/wxPython4/extras/linux/gtk3/ubuntu-16.04 wxPython # For Linux 16.04
Or download from last version from <https://wxpython.org/pages/downloads/>
Could you try by the GIT command
sudo apt-get install git
sudo -H pip3 install -U git+https://github.com/xesscorp/KiCost
or download manually downloading by https://github.com/xesscorp/KiCost/ and running
sudo -H pip3 install -U setup.py # From the folder that you downloaded and extracted
Appear that the version of the pip (official release) have a import problem already fixed on new codes.
I installed using GIT it successfully installed but manual installation not
ajay@ajay-Lenovo-G500:~/Desktop/KiCost-master$ sudo -H pip3 install -U setup.py
Collecting setup.py
Could not find a version that satisfies the requirement setup.py (from versions: )
No matching distribution found for setup.py
After install KiCost using the GIT (which take the last code version on the development)
The command
install when you download accessing the web page and download by your self. So this you will not use, @ramprasadajay.
Yes, I did the same thing. I installed git and then installed Kicost using git as you mentioned, it successfully installed kicost 0.1.47 and when I tried running kicost it returning the same message. Then I tried installing it manually but that installation returning with error as I showed you in the previous reply
I reinstalled wxPython and ran that command it returned the result. But when I tried to run KiCost I got this error msg, I installed Libreoffice also but getting the same result
/usr/bin/libreoffice: 174: exec: /usr/lib/libreoffice/program/oosplash: not found
Traceback (most recent call last):
File "/usr/local/bin/kicost", line 11, in <module>
sys.exit(main())
File "/usr/local/lib/python3.6/dist-packages/kicost/__main__.py", line 239, in main
kicost_gui() # Use the user guide if no input is given.
File "/usr/local/lib/python3.6/dist-packages/kicost/kicost_gui.py", line 990, in kicost_gui
frame = formKiCost(None)
File "/usr/local/lib/python3.6/dist-packages/kicost/kicost_gui.py", line 293, in __init__
subprocess.check_output(['libreoffice', '--version'])
File "/usr/lib/python3.6/subprocess.py", line 336, in check_output
**kwargs).stdout
File "/usr/lib/python3.6/subprocess.py", line 418, in run
output=stdout, stderr=stderr)
subprocess.CalledProcessError: Command '['libreoffice', '--version']' returned non-zero exit status 127.
Hurry! it’s working @hildogjr. I installed libreoffice by command line instead of downloading deb package fixed the error. Thank for the help @hildogjr and developing this amazing GUI for this amazing plugin.
Now I am getting this error while I press Kicost It! @hildogjr
(kicost:5282): Gtk-CRITICAL **: 18:07:38.902: gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkScrollbar
[xcb] Unknown request in queue while dequeuing
[xcb] Most likely this is a multi-threaded client and XInitThreads has not been called
[xcb] Aborting, sorry about that.
python3: ../../src/xcb_io.c:165: dequeue_pending_request: Assertion `!xcb_xlib_unknown_req_in_deq' failed.
[xcb] Too much data requested from _XRead
[xcb] This is most likely caused by a broken X extension library
Aborted (core dumped)
I got this intermittently. Please, generate a bug/issue track on the GitHub · Where software is built (also in the about tab of KiCost have a link for this).
